Old 06-14-2017, 09:52 AM
Norcalrv7 Norcalrv7 is offline
Default Dog copilot
Rebel, my girlfriends bulldog is my hangar and flying buddy while she is at her real job.
19059045_1717377784946618_4219493661889592268_n by Caleb Lesher, on Flickr
Flying RV-7A With SDS Electronic fuel injection
ATP CFI A&P
Based at EKA, Northern CA
Old 06-14-2017, 09:59 AM
izzybear's Avatar
izzybear izzybear is offline
Default Nice!
Made my day Caleb - thanks for posting! May you have many, many more flights together
Jim
RV-8 N223GT (reserved)
Finish - arrived 10/7/15
Fuselage - arrived 3/14/14
Wings - arrived 3/7/13
Builder # 83331
www.mykitlog.com/izzybear
VAF Dues gladly paid up till December 2018
"The ultimate responsibility of the pilot is to fulfill the dreams of the countless millions of earthbound ancestors who could only stare skyward and wish." - Unknown
Old 06-14-2017, 06:16 PM
eddieseve eddieseve is offline
Love it.
Does the engine noise bother him?
How did you restrain him on the front seat?
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
820 hrs Mar 2018
Old 06-15-2017, 01:04 AM
Capt Capt is offline
That's one ugly dog. Hope yr G/F is better...lolol That's one thing I would never do, take a dog in a plane!
Old 06-15-2017, 02:15 AM
Hornet2008 Hornet2008 is offline
Talking
Do you not need mixture with SDS electronic fuel injection? Just looks odd not having that little red knob. Opens up a brace of questions regarding leaning ect.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying
Old 06-15-2017, 02:21 AM
GThalheim GThalheim is offline
I don't see a mixture control next to the prop and throttle controls. Does the EFI have a mass air flow sensor or something like that? Or does it use an algorithm?
Old 06-15-2017, 06:01 AM
rmartingt's Avatar
rmartingt rmartingt is online now
That's the great wonderful thing about EFI--no need to futz about with a mixture knob like it's 1950
This system uses manifold pressure and RPM with a programmed fuel map. You can also schedule your ignition timing, and there's an optional "lean switch" function that leans out by a set amount and advances the timing.
There actually is a small mixture knob that you can use for initial tuning (dial in what you want, note the setting, and program it in), to lean manually if desired, or to compensate for an abnormal condition. But the great thing about it is that once it's set up, you shouldn't need to mess with leaning any more. For normal ops you'd just leave it at the halfway mark. In the pics it's right below the round programmer, next to the red-guarded switch in the center of the panel.
Ross is working on a closed-loop function that will adjust fuel delivery to meet a specified O2 sensor target. That's more challenging due to the need to handle sensor failure, and due to lead fouling of O2 sensors.
RV-7ER - fuselage structure in work
There are two kinds of fool in the world. The first says "this is old, and therefore good"; the second says "this is new, and therefore better".
Old 06-15-2017, 06:52 AM
I'm sure there is an obvious reason for this (turbulent intake flow?, bad failure modes?) but wouldn't it be easier to do the air flow on the intake like they do in cars, rather than on the exhaust?
Old 06-15-2017, 06:59 AM
Flynjay Flynjay is offline
Cars measure the amount of O2 in the exhaust to determine proper mixture ratio. The intake manifold pressure is there to calculate the intake volume, required for calculating fuel injection volume matching to air intake volume.
Open loop, measures the intake parameters and uses a table to determine fuel injection volume. Closed-loop adds in the exhaust gas measurement to modify the table real-time.
Old 06-15-2017, 08:02 AM
daddyman's Avatar
daddyman daddyman is offline
NorcalRV7,
Yes, but is she IFR rated?
Isn't colorblind an issue with dog copilots?
Daddyman
