Old 05-18-2017, 07:10 AM
prkaye prkaye is offline
Default cracks in Engine mount PC
Doing my annual recently I noticed these cracks in the Engine Mount finish... I assume these cracks are only in the Powder Coat, but I thought I'd post them here for opinions... should I be worried about these, or do anything specific about them?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 05-18-2017, 07:27 AM
wilddog wilddog is offline
They will need to be cleaned up for painting and while you are at it put some dye on it to check for cracks. Most of them look like paint cracks but you need to take a closer look, especially at the lower one extending from the gusset.
Old 05-18-2017, 08:02 AM
To verify that the cracks are only in the paint/powder-coat, do you recommend that I chip/peel away the coating around those cracks to get a closer look underneath?
Phil
RV9A (SB)
Ottawa, Canada
Old 05-18-2017, 08:11 AM
A good quality paint thinner should resolve the powder coat. Use proper personal protection, gloves mask etc, and dampen the powder coat with the thinner. it will not take too many applications before the coating will wipe right off. Lacquer thinner used to work although with new paints I am not sure if you can still get it.
Check with a local paint supply house, car quest, etc for products.
It just looks like flaking powder coat but as it is no longer offering any surface protection from rust you should clean it off, check for cracks and repaint the local area.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger flying #153
Fairlea Field
fairleafield@gmail.com
Old 05-18-2017, 09:49 AM
JonJay's Avatar
JonJay JonJay is offline
This issue is typically caused by poor prep prior to the application of the powder coat. You may find some surface corrosion under there so treat accordingly after you strip it for inspection. I have found over the years that Vans vendor(s) seem to be a bit hit and miss in this regard. This is one of the worst I have seen.
Poor prep when painting "wet" typically shows up during the process. With powder coating, it just bridges over and makes it appear to be sound when it may not be.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-18-2017, 10:47 AM
Default paint
any recommendations for what kind of paint to use on this after stripping/cleaning?
Phil
RV9A (SB)
Ottawa, Canada
Old 05-18-2017, 11:09 AM
JonJay's Avatar
This might help.
http://www.vansairforce.com/communit...ne+mount+paint
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-18-2017, 11:33 AM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
The Van's powdercoat color is a stock color, and you can get it in spray cans. I don't have the number handy, but you can find it via a search here.
Old 05-19-2017, 06:28 AM
terrykohler terrykohler is offline
Default Unless You're Removing the Engine...
Spray painting may not give you very good coverage. Clean to bare metal, inspect, and brush on a high quality anti-corrosion paint. I'd rather deal with a few brush marks than be unsure if everything was properly covered.
Terry, CFI
RV9A N323TP
Old 05-19-2017, 08:31 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default Mount
Remove the engine mount. Strip it. Inspect. Paint. Powder coat just hides rust.
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
