Old 04-19-2017, 09:08 PM
gyoung's Avatar
gyoung gyoung is offline
Default Spherical magnets
I just received an order of some gear leg fairings from Van's. Included was a sub-kit Bag 1002 with 20 spherical magnets and nylon washers. While they are really fun to play with, I can't find any reference to how/where they are used. They aren't on the included drawing and I've searched VAF and the construction manual to no avail. My only thought is to hold the fairings to the gear legs while mounting/aligning them. What am I missing?
Greg
1950 Navion - flying
RV-6 - 15 yrs and 96.3% done
3.5 L-2 projects on deck
Old 04-19-2017, 09:54 PM
Try Page 5-18 of the latest rev. level of Section 5
Scott McDaniels
Hubbard, Oregon
Old 04-19-2017, 11:24 PM
gyoung's Avatar
How 'bout dat... hole locators. This is my first experience with your gray coating but the magnets will sure beat the old backlight method for my semi-transparent wheel pants. Guess I gotta bone up on this century's methods. Thanks Scott!
Greg
Old 04-20-2017, 07:50 AM
Bill Boyd's Avatar
Default Magnets!
... the real secret to Van's Total Performance.
(Don't tell anyone.)
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 04-20-2017, 08:14 AM
rph142's Avatar
rph142 rph142 is offline
The plans have come a long way since my RV-3! The equivalent 37 page manual was summarized in one sentence that basically said "Good luck and have fun!"
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 04-20-2017, 09:09 AM
OkieDave OkieDave is online now
I have to say, that's a pretty clever idea. I like it!
Old 04-22-2017, 03:45 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Default I learned something too.
VAF# 835
Builder # 73072
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
VAF 2018 Sent
Old 04-23-2017, 09:49 AM
JonJay's Avatar
JonJay JonJay is offline
In the day, my neighbor, an early RV6 builder, made a kit with small magnets and a viewer. You glued the magnets onto the back side of the rib flange where you wanted to drill. The viewer was a small piece of cardboard with a plastic window and a bullseye. When you passed over the magnet, the particles in the viewer gathered together and you could line up the bullseye which had a small hole for a marker. The drill popped the magnet off as it pushed through.
This was back when there where no pre punched skins and came in handy for fuselage bulkheads hidden under the skin.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 04-23-2017, 11:19 AM
It's a bit off the topic of this excellent hole-finding method, but I've found that two strong flat magnets do a great job holding pieces of aluminum together in places where clamps can't reach.
Mine are 1/2" diameter and about 3/32" or 1/8" thick.
Old 04-23-2017, 07:24 PM
You can still make one of the viewers. Very handy in certain situations. I used one on my RV-6 and again, skinning the leading edges of an Aeronca Champ.
Here's the starting point:
https://www.amazon.com/Magnet-Source...agnetic+viewer
Then you punch a hole in the center.
Tape or glue a magnet on the "other" side of the surface you want to drill (and in the correct location for your desired hole), and all you have to do is use the card to locate the magnet, mark it through the hole you poked in the card, and drill away.
Easy peasy.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
