Russell said:Does anyone have any experience with an RV9 with an O-235 with 108 HP instead of the usual minimum 118 HP???
Russ
My answer is that the 180 HP engine I am interested in installing is not the O-360. I am looking to install the ECI IO-340 which is reported to put out 180-185 HP and weigh the same as the O-320. If this is all true then your arguments for using this engine do not stand up.N941WR said:1st. Why do you want a larger engine?
If the answer is to go faster, build a -7.
If the answer is for better climb, what's wrong with 2000 solo/1400 GW feet/minute climb?
The -9 is designed with a 1750 GW in mind. Adding the bigger engine detracts from your useful load.
Also, the -9 only holds 38 gallons and the O-360 burns more fuel than the O-320. This might have you stopping more frequently.
If you up the GW, that 50 MPH GW stall will go up, probably to match the -7's, or close to it.
This is something I have never heard before concerning thinner skins. Can you tell me where you got this information and where I can find out more about it? I am not aware that the skin thickness is any different from one RV model to the next.N941WR said:the -9 and -7 are very similar but the tail structure of the -9 is different and uses thinner skins than the -7. Just think of the additional beating those 20 extra HP's will give that tail.
N941WR said:2nd. Why do you want to mess with flutter?
- 'nuf said
Steve,RVbySDI said:This is something I have never heard before concerning thinner skins. Can you tell me where you got this information and where I can find out more about it? I am not aware that the skin thickness is any different from one RV model to the next.
Still looking for an explanation of why Van says the red line limit on the 9's refers to TAS and not IAS
And if that is the case, what does the red line on the airspeed indicator refer to?
karl said:Geico: I agree 100%. Still looking for an explanation of why Van says the red line limit on the 9's refers to TAS and not IAS. Check out the spec site on Van's web site for the 9 where it links to an article why 180hp should not be used. very confusing to me. To fly within the 210TAS limit one would have to always be doing a computation unless he had a Dynon or other way of computing TAS. And if that is the case, what does the red line on the airspeed indicator refer to?
Rick of Austin said:Haven't flown yet but am very close to flying the RV-9a with a 180hp Superior engine and a Sterba prop. With the 180 hp engine and the wood prop I make less thrust that a 160 hp constant speed right?
It surprises me how many people feel that its a risk when the RV-6 and the RV-9 have exactly the same VNE hence the same resistance to flutter. Of course with a lower stall speed we have a lower manuvering speed which is what the limiting factor is in rough air and that is basically the topic of the correspondence Van wrote describing why he chose 160 as the maximum hp for the 9.
Am I missing something here? Are there other factors or risk exposures I am not aware of.
Thanks in advance.
Daver said:Will a larger engine throttled back use less, the same or more fuel than a
smaller engine at a higher throttle setting?
Sorry, in advance, if this is a stupid question.
rtry9a said:Yukon,
Greatest efficiency was not the question; whether two engines burn about the same amount of fuel to produce the same output was.
My understanding is that IC engines are most efficient at their adbiabatic peak (point of greatest combustion pressure, which generally falls at the engine's torque peak, not the HP peak. Am I wrong?
From my non-expert experience and from my long term research in trying to ferret out the answer to this very question myself I have determined that there may be a difference but only in technical terms. An engineer can probably give you all the numbers to determine exactly what these differences would be. However, in what I have researched, when it comes to the size differences in engines we are talking about in our situations, any measurable differences in fuel burn would be so small they would arguably not even be noticeable, let alone worth worrying over.Daver said:Will a larger engine throttled back use less, the same or more fuel than a
Yep at 2800 rpm some models of O235 are 118HP.Russell said:Does anyone have any experience with an RV9 with an O-235 with 108 HP instead of the usual minimum 118 HP???
Russ
RVbySDI said:I cannot answer for Karl but I am considering the same HP issues as he is. I would like to interject my answers to one or two of your questions.My answer is that the 180 HP engine I am interested in installing is not the O-360. I am looking to install the ECI IO-340 which is reported to put out 180-185 HP and weigh the same as the O-320. If this is all true then your arguments for using this engine do not stand up.a) As far as going fast is concerned, I am not convinced the -7's are a faster airplane than the -9's. At least not as a general rule. I am sure there are plenty of -7's out there that will be faster than a -9 but my guess is that as more -9's start flying we are going to find they will hold their own against the general population of -7's in the speed department.This is something I have never heard before concerning thinner skins. Can you tell me where you got this information and where I can find out more about it? I am not aware that the skin thickness is any different from one RV model to the next.
b) In my case I have intentions of flying in and out of Rocky Mountain airports with high elevations in the summer months. I am talking about airports in the 8,000 - 12,000 MSL range on days with temperatures in the 90 + degree Fahrenheit range. In this environment having all the climb power I can muster will be important.
c) Running the IO-340 at 55% to 65% should allow for as good or better fuel economy as the O-320 at 75%. It should also allow for a longer life for the engine.
d) If the weight of the engine is not higher than that of an O-320 then there will not be an increase in GW just because you put a "bigger" engine in the airplane. More horsepower does not have to equate to a heavier engine.
e) This will not have any negative effect on the stall speed either because there will not be an increase in GW.
Steve, I am interested in using the ECI IOX-340 for the same reasons that you have espoused. Are you still considering this option? I started a thread a couple of days ago without being aware of your commentsRVbySDI said:I cannot answer for Karl but I am considering the same HP issues as he is. I would like to interject my answers to one or two of your questions.My answer is that the 180 HP engine I am interested in installing is not the O-360. I am looking to install the ECI IO-340 which is reported to put out 180-185 HP and weigh the same as the O-320. If this is all true then your arguments for using this engine do not stand up.a) As far as going fast is concerned, I am not convinced the -7's are a faster airplane than the -9's. At least not as a general rule. I am sure there are plenty of -7's out there that will be faster than a -9 but my guess is that as more -9's start flying we are going to find they will hold their own against the general population of -7's in the speed department.This is something I have never heard before concerning thinner skins. Can you tell me where you got this information and where I can find out more about it? I am not aware that the skin thickness is any different from one RV model to the next.
What type 0-360 are you using?Geico266 said:I like the analolgy about motor gliders, and you don't slam the go peddle of your car to the floor backing out of the driveway.
Power management is everything with an "over powered" airplane. Respect V's, watch the weather for turbulance indications and I'm good to go. I have 323 hours in my 9A with an 0-360. I can cruise around buring 5-6 GPH, or push it to 200 MPH burning 10 GPH to get somewhere. Climbs near 3,0000 FPM if I needed.
No problems so far.
Experimental has it's benifits.
