Old 03-25-2017, 09:41 AM
RKURRLE RKURRLE is offline
Default RV-8 quickbuild Service Bulletin 16-12-16
If your center section is missing the bolts, how are you getting access to put the bolts in? I read Van's suggestion of putting 1 inch holes - but that seems like it would be very difficult to put the nuts on and tighten through those 1 inch holes. Looking for alternatives.
Bob Kurrle
paid 2017 dues
Bob Kurrle
Daytona Beach, FL
RV-7. N56RK
First flight 10/03/2011
2017 dues paid
Old 03-25-2017, 11:40 AM
cfiidon's Avatar
cfiidon cfiidon is offline
Default No Holes Required
Bob,
Review all the posts in the original thread, especially Luke's post #21:
http://www.vansairforce.com/communit...=145000&page=3
I used his method.
1. Loosen the rudder pedals
2. Remove the control column sliding it forward (make note of hardware for re-assembly)
3. I used a Rigid See-Snake camera to light and view inside the center section
4. I used the Aircraft Tool Supply nut/washer holding tool but you could fashion something on your own
5. I used a box end wrench taped to a rigid aluminum tube.
The inside 8 bolts are "easy". The outer four more difficult but do-able. The first six took me 6 hours. The second six took me three. I did it alone.
Plan on acetaminophen and a massage afterward.
Don
RV-8 QB Titan ECi 191HP XIO-360
WW200RV Dynon D180 HS34 AP74
GNS430 SL30 GTX327 PS8000B Navworx ADS600b
"Pilots are alchemists... we turn gold into lead."
Old 03-26-2017, 05:52 AM
Smile Thanks
Don
Thanks for the "no holes" suggestion. Sounds like a winner without cutting holes and fabricating patches. I will schedule my massage and stock up on ibuprofen!
Bob :
Bob Kurrle
Daytona Beach, FL
RV-7. N56RK
2017 dues paid
