Old 03-18-2017, 12:07 PM
Default a couple printed ideas
rocker switch protector. use small velcro on each end to secure.
infinity stick cover. first trial.
looks goofy, works great. no more snagged switches when climbing in. that could ruin your day. just drop it on and it finds the home. done.
label embossed
print with multiple colors and glow in the dark plastic?
label recessed
Old 03-20-2017, 08:33 PM
Default fuel drain fairing
maybe a little proseal on the cylinder is enough to adhere. weight = 16 grams. first trial, size is not final. plastic cost = $ 0.42. may also improve the life of the o-ring since it will eliminate vortex shedding vibration of the stem that is in the airstream.
Old 03-20-2017, 09:11 PM
crabandy crabandy is offline
Sweet, I will take 2 of the fuel drain fairings, where do I send the $0.84?
How about a smaller fairing for the fuel vents on the belly?
RV 7 200 hours and counting
12/17 donation
Old 03-20-2017, 09:12 PM
Steve, you are having way too much fun there!
rockwoodrv9a
Meridian Idaho
rockwoodrv9a@gmail.com
O-320 D2A
Awaiting DAR Inspection
I'll throw a couple of these in a back for Oshkosh. Fly away with a "faster" airplane.
Old 03-20-2017, 09:38 PM
Default Fuel drain lock
On the fuel drain fairings could you put a hole in it such that a small lock can be inserted so that it will prevent someone from stealing fuel? I dont know why this occurred to me, not that i live in LA or anything like that.
Thank you
John S
Fuselage started
Old 03-20-2017, 09:41 PM
John, I wouldn't do that for anyone except you. Let me know when you need it. Steve
Old 03-21-2017, 04:50 AM
From concept to holding in the hand in about two hours and I had to watch a youtube video for training. I am still amazed by this technology.
I see Solidworks can complete CFD airflow analysis. I'll post a couple slides of that. Not that this simple fairing needs any analysis but just to share. Maybe someone can chime in on that.
My youngest daughter, 9th grade, runs circles around in solid modeling and is beginning to talk about stress analysis. Now we have something to discuss!
Old 03-21-2017, 05:37 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Nice work!!
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
www.PuertoRicoFlyer.com
Old 03-21-2017, 05:38 PM
rzbill's Avatar
rzbill rzbill is offline
PLA or ABS and are they hollow?
Bill Pendergrass
RV-7A: Flying since April 15, 2012. 690hrs
YIO-360-M1B, mags, CS, GRT EX and WS H1s & A/P, Navworx
Unpainted, polished....kinda'
My RV Construction Page
