Old 03-17-2017, 09:27 AM
taverroi's Avatar
taverroi taverroi is offline
Default RV7A UL POWER PROJECT - 200HP 520iS FWF UPFIT WITH PICS
OTHER PICTURES AT POST #43, #47, #53, #54, #57 and #62
Ok Gents,
As promised here it is. Pics of my 200hp UL Power Plant Upfit on my RV7A.
All work is being completed by Ray Lawrence out of Sanderville Ga. Please contact him direcly with and questions about the power plant itself and prop itself..Im just the money man..he is the brains behind the install. A good friend and an incomprable AC Mechanic and Builder.
His Contact: 478-232-9560
We encourage all comments, encouragements, and questions.
Ray will be giving the answers most of the time. I will be updateing with pics as the project advances. FWF first then the all new panel.
The plane will be at Sun N Fun in Paradise City if you want to see it first hand. The FWF with Cowl complete and painted is our goal for the show but that is ambitious at best. Ray will be in attendance.
First pic starts at the pick up of the project, then with the Egg still installed and its removal, clean FW, eng mount, engine install pics, and finally muffler install on one side and brand new upgraded gear leg and fork with Anti Splat installed. Finally the cowl off to the side that will cover it all.
Enjoy, and fire away!
Tango (I'm Stoked!)
Tango Victor
1st One RV7A N623CM Slider
2nd One RV6A N555JN Slider
3rd One RV6A N752JW Slider
4th One RV8A N38GC Slider
5th One RV6A N129JZ Slider
6th One RV8A N338BS Slider
7th One RV6A N973JT Slider
8th NOW RV7A N307RV Tip Up
Old 03-17-2017, 09:45 AM
bret's Avatar
bret bret is offline
Right On! can't tell from the pics, but is the rear of the engine offset to account for P factor? how far forward did the prop end up? I looked at this set up for my 7a before going Lyc. Looks good!
2019 gladly supported
Old 03-17-2017, 09:49 AM
Mike S Mike S is online now
Mikey likes it
Old 03-17-2017, 10:21 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default wow
Good on you!
Looks nice.
Thanks for documenting this!
Looks like a James Cowling too....
looking forward to updates.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 03-17-2017, 10:31 AM
bhester's Avatar
bhester bhester is offline
Exclamation Nose wheel stop bracket
Your nose wheel stop bracket is installed incorrectly. This is what most likely cause the nose wheel collapse on the aircraft in another post that just showed up a day ago. Please look at the SB that explains this and then get it installed correctly. Looks good other than that!
http://vansaircraft.com/pdf/sb14-12-22.pdf
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2018 VAF donator - alot better than any magazine subscription
Old 03-17-2017, 10:32 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Very cool!
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 03-17-2017, 10:39 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is online now
Good catch Bobby!
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-17-2017, 11:32 AM
taverroi's Avatar
This install has the EXACT same offset as Van's Design.
Prop forward dimention is 11 inches.
Tango Victor
Last edited by taverroi : 03-17-2017 at 01:00 PM. Reason: new complete information
Old 03-17-2017, 11:35 AM
taverroi's Avatar
Originally Posted by Bob Martin View Post
Good on you!
Looks nice.
NO, not a James Cowl. This Cowl is specifically designed, prototyped and made for this specific installation option with this engine on an RV7A
Tango Victor
Old 03-17-2017, 11:38 AM
taverroi's Avatar
Good eyes man!
But the stop bracket is already broken and is only being used temporarily for set up to allow for the engine installation. It will be replace with new and of corse installed correctly at that time.
Tango Victor
