Old 03-11-2017, 05:02 PM
rv3flier's Avatar
rv3flier rv3flier is offline
Default facet fuel pump replacement
Is there room to replace the facet fuel pump w/o removing the fuel tank or anything but the access panel in the floor?
Old 03-11-2017, 06:10 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
I am going to say yes. It's a little tight.... may need to remove an inspection panel on the bottom too ...
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 260 Hrs on the Hobbs
http://unicom12.blogspot.com/
Click on above for build site
Old 03-12-2017, 04:56 PM
Dpick23 Dpick23 is offline
Default replacing electric fuel pump
I just replaced my fuel tank (old sight gauge style finally started to leak) and decided to also replace the electric fuel pump (still running great at 300 hrs). I was able to get the pump out one of the inspection holes at the belly of the aircraft- not lots of room but doable! I used a crows foot wrench to loosen the fuel lines from the pump. Worked well! Enjoy!
Old 03-27-2017, 07:10 AM
rv3flier's Avatar
Thanks for the confirmation on pump removal.
