Old 03-04-2017, 10:03 AM
kentlik's Avatar
kentlik kentlik is offline
Well, this is really cool! Clean setup. Keep us posted!
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-04-2017, 10:22 AM
Ralph Inkster Ralph Inkster is offline
Is that 3 batteries on the firewall?
Ralph
Maintain lots, upgraded & repaired some, modified more, rebuild a few, & built 4 of 'em
Old 03-04-2017, 10:28 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
I believe Caleb's induction tube will be fine here. The bends are smooth and the inside area is larger than the TB aperture minus the shaft and blade area by a fair amount. The TB already has a lot more area than the Marvel carb venturi. You can always see what MAP is vs. baro to find out if there is a loss here at WOT and high rpm.
Dave Ander's temperature testing of his injectors mounted under the cylinders found them within acceptable ranges but more temp data is always good as this location is slightly different. Have to watch the IR off the exhausts down low.
I see your earlier pix showed a loop type rail system and later the individual lines.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 426.1 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 03-04-2017, 10:48 AM
Toobuilder's Avatar
I didn't mean to imply that the induction tube setup is going to be a performance detriment (compared to the Vans setup), only that is is not "optimal". Truth be told, the difference between this setup and "optimal" is likely very slight, perhaps immesurable, but is likely there. You do have my respect for developing and executing a solution however. Nice to see you didn't throw in the towel just because the part you needed wasn't available from a vendor.
I would suggest a small drain hole at the bottom of the tube if you don't have sniffle valves though. That airbox looks like a great funnel for water!
Michael Robinson
______________
RV-8 - Flying
Old 03-04-2017, 01:18 PM
Norcalrv7 Norcalrv7 is offline
Sure is... My airplane turned out quite tailheavy. After removing the Subaru. I moved everything as far forward as I could, and added a prop spacer, but was still looking at exceeding the aft limit with 2 passengers and bags. I decided to add a 3rd standby battery on a switch to my critical bus instead of adding lead. Not sure why my airplane is so tailheavy. I'm guessing a combination of the lightweight 360(no mags, carb, or accessories) and the fact that my plane was painted clearcoat.... And lots of it by the original builder.
Caleb
Flying RV-7A N542LC 800 hours+ With SDS Electronic fuel injection.
Pieces of an RV-8 in the back of the hangar
ATP CFI A&P
BE-200 Air Ambulance driver
Based at EKA, Northern CA
Old 03-04-2017, 03:04 PM
Toobuilder's Avatar
Caleb
I don't claim to be an authority on the -7A, but a 360, a Hartzel on a spacer and 3 batteries on the firewall... That just doesn't pass the giggle test.
Are you confident in the W&B? Maybe some other -7 owners can jump in and set me straight, but without a smoking gun driving weight in the tail, it seems more likely that its a simple math error.
Not being critical, just seems like a red flag.
Michael Robinson
______________
RV-8 - Flying
Old 03-04-2017, 03:11 PM
DanH's Avatar
DanH DanH is offline
Seems like a PC680 at 48" aft of datum would have moved the CG about 1/2", tops. Am I wrong? Don't have a 7A W&B spreadsheet handy.
Dan Horton
RV-8 SS
Barrett IO-390
Old 03-04-2017, 03:41 PM
I've been hoping to find a brick of lead in the tail... But no luck yet. I'm almost embarrassed to say how heavy it is! I weighed it on some borrowed car scales. 1168 total. 452 left main, 445 right, and 271 on the nose. The plane has at least 3 layers of paint on the exterior, and the inside of all the structures were painted heavily by the builder. Maybe someone has some data about cg before and after paint?
Caleb
ATP CFI A&P
Old 03-04-2017, 04:11 PM
rv6ejguy's Avatar
The 6 cylinder Sube is no lightweight. Paint looks better than than a lump of lead although maybe not as efficient.
This weighs about the same as my 6A. I have one 680 between the rudder pedals and another similar sized battery just aft of the baggage bay.
Old 03-04-2017, 04:37 PM
Walt's Avatar
Walt Walt is offline
I've been hoping to find a brick of lead in the tail... But no luck yet. I'm almost embarrassed to say how heavy it is! I weighed it on some borrowed car scales. 1168 total. 445 left main, 452 right, and 261 on the nose. The plane has at least 3 layers of paint on the exterior, and the inside of all the structures were painted heavily by the builder. Maybe someone has some data about cg before and after paint?
Caleb
That nose seems awfully light!
My own 7A numbers are MLG 444/442, NLG 302, 1188 total (chubby girl I know).
Other examples of 7A's with CS props I've weighed:
439/436/292
432/444/309
428/425/306
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
