Old 03-02-2017, 01:26 PM
salto salto is offline
Thank you very much Stoney that is a great help. As stated before the Digikey site does tend to make the eyes glaze over.
If what I have ordered is not correct I'll get the right one using those numbers.
Thanks again.
Kit 140241
Tail Feathers done
Fuselage kit completed.
wings almost complete.
Flaps and ailerons done.
Canopy next. Phew!
Old 03-02-2017, 09:44 PM
PNLBLDR PNLBLDR is offline
I believe all the connectors you are referring to are part of the "fuselage" harness. WH-00125. This harness will mate with all the existing connectors at tail/wing roots/sticks, etc.. and bring it all up behind the panel. Unless you intended to craft this portion on your own?!
Nick Millard
SteinAir Tech, 8 years..
Old 03-03-2017, 02:36 AM
Thanks Nick, nice job on the harness by the way 👍
You are quite correct with what you say however an issue arises with wiring the control stick grip of choice as you need to run the wires yourself so the male end of the plug would be handy and same goes for the navigation lights.
The other issue I have run into is I need to de-pin the harness plug for the control stick as I can't get it through to the stick even though I notched out the bulkhead holes. So suggestions for future harnesses would be to leave off the control stick wiring plug leaving it free in the bag with its mate and also the navigation light male plug with some pins free in the bag.
Kit 140241
Tail Feathers done
Canopy next. Phew!
