Old 02-11-2017, 08:52 AM
T.O.Craig T.O.Craig is offline
Default Alternate Static Air
Howdy to all,
I am installing my static air system and have been wondering if others are installing a alternate static air input that I could open if I ever had a problem with ice (hope not) or contamination. A valve could be close to me that I could open that would at least give cabin air as a source..
If so, are there any valves that would be better than others
Thank you all for your valued input:-))
Craig Rufi
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2017
Old 02-11-2017, 10:59 AM
terrye terrye is offline
I'm using a Clippard TV-2SP panel mounted valve with a Clippard 15070 muffler in the open port (only to prevent debris from entering the valve).
http://www.clippard.com/part/TV-2SP
http://www.clippard.com/part/15070
Terry Edwards
RV-9A (Fuselage)
2017/2018 VAF Contribution Sent
Old 02-11-2017, 11:15 AM
Brantel's Avatar
Brantel Brantel is offline
Use the same one...Got it from Stein:
http://www.steinair.com/product/pito...toggle-switch/
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-11-2017, 11:21 AM
BillL BillL is online now
+1 Yep - me too
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 02-11-2017, 12:15 PM
Raiz Raiz is offline
Default Alternate alternate static air
I've been contemplating doing this with a small solenoid valve and an electrical switch on the panel. The main reason is that Stein's (excellent) valve doesn't look right on my panel alongside the other (rocker) switches. One other benefit would be that I can monitor the switch and have a warning on the EFIS. The downside is that this function is electrically dependent. The other option would be to hide Stein's valve away somewhere but then it's not obvious to anyone else who flies the plane. I don't have to decide yet, so I'm procrastinating.
Old 02-11-2017, 01:11 PM
gasman gasman is offline
If you ever sat in a Piper PA 28 series pilot seat, you would find the alt static source sticker near your right knee with the simple 1/4 turn valve under and behind the panel lip. Simple and easy.......
Think about how you do it..... and later it can also be used as a test port.
VAF #897
2017 =VAF= Dues PAID
Old 02-11-2017, 01:15 PM
Brantel's Avatar
I put one of these on mine. Changes the look and makes people leave it alone.
Old 02-11-2017, 01:34 PM
Default And again . .
+1 Yep, me too.
Bill
1st Flight 1-27-18
2017 Dues Paid
Old 02-11-2017, 03:13 PM
N427EF N427EF is offline
Default Not sure why??
Why are you even contemplating an alternate static source?
In 35 years of flying, I have never heard of anyone having a static line blockage.
Isn't one of the reasons for installing 2 static ports as per plans to build redundancy into the static system?
We don't install 2 pitots where blockage of ice or bugs is much more common
than on static ports.
Like piper and Cessnas, an alternate static port can be tucked away under the seat or behind the panel where it is still accessible from the pilot's seat.
That is a neat looking switch from Stein.
Not sure how you would monitor your static pressure.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 400 plus hours
Over 2500 Gallons of E10 mogas burned
Don't believe everything you know.
Old 02-11-2017, 04:14 PM
Default But...
With the electrical switch you could monitor switch position on the EFIS...
Then you would know where the switch was but what about the relay? And even if you monitored the switch AND the relay, you would still not know if the opening was plugged up...
"...the job of an engineer is to make simple things complicated..."
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
