Old 01-03-2017, 09:40 AM
tims88 tims88 is offline
Default RV-10 #41741 Colorado
On January 1st I started work on the empennage kit for my RV-10! After nearly a year and a half of research, planning, preparing, and dreaming it's an incredible feeling for my wife and I to finally be able to say that "we are building an airplane" instead of "we are going to build an airplane".
A huge thanks to Mike (ppilotmike) who showed us how to build our first practice kit, and Justin (J Twilbeck) and Myles (met through EAA chapter 43) who took us for rides in their RV-10's.
This website and multiple build logs I've found online have been extremely educational and motivational while we have been getting ready to start our build. It's inspired me to try to maintain my own blog documenting our build. I started one a couple months ago when I started building my workbenches but it still needs work and will try to add more content in the coming weeks.
https://timsrv10blog.wordpress.com/
Tim
Arvada, CO
RV-10 In Progress
Old 01-03-2017, 09:54 AM
unitink72 unitink72 is offline
Default welcome
Welcome to the club! I'm just a few months ahead of you.
If you haven't already, order some proseal from Van's. You'll need it about 3/4 way thru the rudder.
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2018 Dues Paid
Old 01-03-2017, 09:44 PM
wirejock's Avatar
wirejock wirejock is offline
Default E-mail group
Tim
Welcome.
There's a group of builders in Colorado who communicate by an e-mail group. Mike is in the group. If you would like to join in, send me an e-mail. Address is below.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-04-2017, 08:40 AM
Thanks unitink72! I actually just noticed that while I was looking ahead in the plans last night. I don't know yet if I'm going to go with the ProSeal or if I'm going to try the tape method mentioned in section 5. I'll be doing some research on the forums to see what people think about the two options. I've got more time than you would think though. I messed up some parts on the VS so I skipped ahead to the rudder while I await the replacements. As soon as those are here I'll probably go back to working on the VS.
I'll be following along on your blog so be sure to point out any tricky steps so I know what to expect!
Tim
Arvada, CO
RV-10 In Progress
Old 01-04-2017, 09:14 AM
AdamB AdamB is offline
Welcome, Tim!
RV10 - #41687
http://adamsrv10.wordpress.com
N810AB Reserved
Old 01-04-2017, 09:49 AM
RV7ForMe RV7ForMe is offline
Welcome! You are in for a wild ride :=)
VAF dues paid until 10/2019
RV7 (N137MX Reserved) - Empennage 95% done
RV7 (N137MX Reserved) - Wings Started...
RV7-A - Rebuild in process
Cessna Rocket 210HP - Best dang 172 Ever made! (sold)
Old 01-04-2017, 10:42 AM
AviatorJ AviatorJ is offline
I used the tape method and was happy with the results and the less mess.
Justin
RV-10 Quickbuild 'Final Assembly'
http://operationrv10.blogspot.com/
Donated for 2018
Old 01-04-2017, 10:49 AM
Default Rudder
Hey no problem. I try to keep it up to date, will see how that goes.
Just cleaned up the proseal last night. It wasn't too bad, I think I made a mess of it and it took maybe 45 minutes at the most to clean it up with Acetone.
Josh T
RV-10 #1750
N67SC reserved
2018 Dues Paid
Old 01-04-2017, 12:09 PM
ppilotmike's Avatar
Default Welcome (officially) to VAF..
..and thanks for the kind words. As others have said, you are in for a ride.
Regarding the Proseal, I'd highly recommend getting the little, tiny 1oz pack from Vans. It's already premeasured and cheap. Apply it to your rudder with a popsicle stick. You won't need lots of Proseal until you get to the fuel tanks, so don't bother buying a lot. When you do get to that point, I highly recommend using the premeasured Semco gun cartridges that Vans sells. They are a little more expensive, but they are premeasured, easy to mix, using an electric drill (get the mix adapter that chucks into the drill) and makes a lot less mess. When I calculated the difference in cost between the cartridges and the "mix it yourself" cans, it wasn't too bad. Plus, I didn't take into account the savings due to waste. IMO, when you batch it yourself, you use a lot more proseal, and the cans go bad after some time on the shelf. Get the cartridges when you're close to needing them and keep them in the beer fridge in your shop. You DO have a beer fridge, right?
Mike Rettig
EAA Chapter 301 www.eaa301.org
VAF Dues Current: Paid for 2019 on 12/03/18
RV-10 (41PX Reserved) Fuselage
http://www.mykitlog.com/users/index....ig&project=803
https://www.youtube.com/watch?v=zKCyX2FXrlw
Old 01-04-2017, 12:39 PM
Pool Shark Pool Shark is offline
I used the VHB tape... Got perfect results setting the double-flush rivets and the trailing edge is "laser-straight"
Not to mention, my Clecos don't have any Pro Seal stuck all over them.
Chris Staiger
Baker's Acres, CA
RV-10 #1711
VS, Rudder & HS Complete 1/29/17; Now, bring on those Elevators...
(VAF Dues Paid thru June, 2020)
