Looking for some ideas. At some point my governor cable pass-thru hole ended up not even coming close to aligning with the attach location on the arm (I have a quadrant, so I need the last hole on the arm). The plans have you temporarily install the baffle ramp so that the pass-thru hole can be located. I think it was all the additional steps after that, that changed the angle of my ramp enough to where it doesn't align anymore.
I'm not interested in building a new FWD baffle assembly.
I could slot the hole as necessary. It just wouldn't look all that great. Even with the grommet installed, I think there will be a decent gap behind it.
I could plug the hole with a plug-button and use a cable bracket like that shown in the picture and run my cable above the engine. The only problem is, to keep the bracket from running into the upper cowl, the existing hole locations on the bracket don't align with the screws on my Hartzell gov. The best I could do is drill two holes and pick up two of the screws.
A third option would be to purchase the bracket from Showplanes. It has several mounting holes along it, I'm sure I could get it to work. The only problem is, it is designed for a different type of cable. So I would have to purchase that as well.
Any other ideas?
Any other ideas?
