Old 11-20-2016, 08:52 PM
CubedRoot's Avatar
CubedRoot CubedRoot is offline
Default November 20th, 2016. 5.25 hours
Today was priming day! The weekend is about the only time I have available where I can get priming done. I am spraying the parts outside to keep fumes out of the house, so I am at the mercy of good daylight. Yesterday I my Shriners unit had a parade, so I drove my little parade car in it, and didn't get home in time to work so today was my work day.
I have the entirety of my horizontal and vertical stabilizers to prime today, and I got started around noon. I first scuffed down all my parts using a maroon scotchbrite pad. My goal was to only remove ay aluminum oxide that may have formed, while also giving the AKZO some tooth to bite into. I did not want to remove the alclad, as I have decided to leave it on the aluminum as an additional layer of corrision protection. The AKZO will be my primary barrier, while the Alclad will serve as a secondary. I also realized that the dimples tend to eat up a scotchbrite pad, so I may start leaving my dimpling duties until after I have primed, this might make scuffing easier and less abusive on the pads.
After I had all my parts scuffed up, it was time to clean them off. My chosen method is to use acetone. This will get rid of any chemicals and oils on the parts and give the primer a good clean surface. I first started by wiping the parts down with a dry micro-fiber cloth, the goal here is to remove any of the dust left from the scuffing.
Then I used paper towels and acetone to clean the parts completely, until nothing was being left on the paper towel. The skins were a little tricky because they had the red ink from the aluminum company, so I wiped it off with acetone first to keep it from smearing across the parts This made it a little easier to clean.
Here's a glimpse of a skin scuffed, cleaned and ready for primer:
Next step was to mix up my AKZO and give it the 30 minute induction time. I took a rough guess and figured a total of 8 ounces should be plenty for these parts. I shook the **** out of each of the AKZO cans, mixed them up with a paint stir, and poured 4 equal parts of "Part A" and "Part B" into my PPS cup. I learned that pouring the clear hardener (part b) first makes it much easier to see the ratio lines on the PPS cups. Here's my primer chilling out in the cup, inducting:
While the AKZO was inducting, I moved my parts outside and onto my spray table. Unfortunately, I had more parts than I had table so I used some old cardboard boxes for the others. I figured I would start flange up on the boxes, so when I flipped them over the flanges would hold my freshly painted surface off the cardboard and not smear it. It worked out pretty good.
Eventually I had all of my parts sprayed, and looking great. This stuff goes on really easily, and dries fast. I am also happy that you don't have to hussle to spray whats in your cup because you have a pretty long working time in your cup. Now, I will admit, my skins have some uneven spots where some areas was sprayed heavier than others, but my main concern was to make sure my skins had adequate coverage. I am not trying to get a show-room quality paint job since the only people seeing this will be me and the inspector. As long as there is good coverage, the AKZO will do its job preventing corrosion. I also had a few small runs on some of the parts, but again, I am not going to worry about them unless the run causes some assembly interference.
I had a few small places on some of my parts that I had to spray again to get good coverage, but I had plenty of AKZO in my gun so I didn't have to mix any up. The 8 ounces (I think the PPS cups are measured in ounces) ending up being just about the right amount, I had good coverage on my skins and parts, and had a little left over to touch up the areas that I missed. After it was all done, I had probably .25 ounce in the bottom of my cup, very very little. I ran some acetone through the gun's gravity feed and then moved the parts from outside onto my work tables to they can finish drying. They turned out really nicely!
I'll let these things harden overnight, and probably start assembling them all together tomorrow or Tuesday night. This green color will look nice against the white/grey hinge brackets and gold colored rivets.
And always, here is a complete album of tonights photos: https://goo.gl/photos/X5mgorU1X4jzY4tE9
Lynn Dixon
RV-7 Slider -
Tail kit Completed - March 2017
Wing Kit Started - June 2017
My Build Log: http://www.theskunkwerx.com
VAF Donation paid for 2017
Old 11-24-2016, 01:13 AM
CubedRoot's Avatar
Default November 23rd, 2016. 4 hours
Tonight its time to rivet some parts together. The primer has been sitting a few days while I spent time with my wife and daughter these past few days, but I had some time tonight to work.
I started out by sorting my parts into the proper "piles". Left / right horizontal stabilizer, vertical stabilizer, front / rear spar, etc. Then I picked up where I left off in the plans for the horizontal stabilizers. This section is the last one, titled "Riveting the horizontal stabilizer".
I first started out by locating and taping up the holes for HS-706, HS-708 and HS-00005 as well as HS-412PP hinge brackets. These holes don't get rivets just yet, so the tape will keep me from sticking one in there. Then I assembled the HS-609PP bars to the HS-603 rear spar channels, cleco'ing every other hole while ignoring the taped up holes.
Then I used AN470AD4-6 rivets to attach the bars to the spar. I used my squeezer to set these rivets. Once I got the first batch set, I removed the clecos and riveted the remainder. I did mess up on one rivet, and flinched the squeezer right as it compressed the rivet, causing it to mess up the manufactured head:
So, I figued now is as good as time as any to drill it out and fix it. I took my time, and used a #40 drill and slowly drilled the head off, then broke it off with a punch. The just used the punch to push out the shop head. The hole wasn't damaged and it look good, so I stuck in a fresh rivet and re-squeezed it with great results:
Next up was to rivet on the hinge bracket, HS-412PP and HS-413PP to the rear spar. At first, when I inserted the rivet called for, AN470AD4-5, it seemed a little long, but a quick search of this forum returned that this is normal, and thats indeed the correct size. So I squeezed them with my squeezer and they turned out good.
Somehow I managed to damage the shop head on one of my HS-412PP hinge brackets. It has a small dent in the top of the shop head, and I am not sure if I should drill it out or if its OK as is. I am going to ask the forum to get advice. It's easy enough to get to as-is, so I can drill it out with no troubles if need be. Here is what it looks like:
It looks like my squeezer set was offset a little on the shop head, and the lip bit into the rivet. We'll see what everyone says is the best route to take.
Here is the link to the thread where I asked everyone: http://www.vansairforce.com/communit...20#post1129120
Next I pulled out the bolts, washers and nuts for the HS-411PP center bearing to bolt it to the spar. I have a decent craftsman torque wrench but I am not sure what torque to use. Nor am I sure which side the washer should go on, bolt head or nut side? So, I just fingered tightened them for now, and will ask the forum for advice.
Here is the link to the thread where I asked this question: http://www.vansairforce.com/communit...19#post1129119
So that was all I accomplished tonight. I have two "pending" items from this work session, that I am waiting on advice for.
1. Should I drill out that rivet in the hinge bracket
2. What torque do I need to use, and which way do the washers go for the HS-411PP center bearing.
Here is a link to tonights photos: https://goo.gl/photos/BGhzL2yD4LqPLxhD6
Lynn Dixon
RV-7 Slider -
Old 11-24-2016, 02:14 PM
CubedRoot's Avatar
Default November 24th, 2016. .5 hours
After reading some of the replies on what I should do about my messed up rivet, I decided to drill it out. I had some time to work on this before we head out to my parents house for thanksgiving, so I figured I would try to drill it out.
First I used a my noxon punch to dimple a point in the head of the rivet. The little center dimple from the factory was barely visible, so I used it to center my punch. Then I took a fresh #40 bit and slathered it in boelube and chucked it up. I put it in the center punched dimple, and turned it by hand a few times to get the bit started. Then I slowly drilled the head down deep enough I could break the head off with the butt end of an old drill bit.
Then I got a bit creative.... I didn't have a receiving bar to drive the rivet into, so I ended up using a pair of vice grips. I stuck the jaws into a pair of leather gloves to keep from scratching the parts, and opened the jaws just enough so the rivet would fall into it. Then I used a punch and a small hammer to gently drive the old rivet out. My vise grips/glove worked pretty good as it received the rivet, and didn't scratch my skins!
I checked the rivet and noticed that I had drilled perfectly center, and then checked the parts and the hole was undisturbed, so a regular rivet should work OK.
I stuck in a replacement normal rivet (AN470AD4-7) and squeezed it making sure I had my squeezer lined up and centered. It turned out great, and took about 30 minutes total time, since I was being cautious. I did end up scratching the nice paint on my bracket, I dropped the stupid punch as I pulled it away and the tip dug into the paint a little. Doesn't appear to be anything than just paint, so I will hit it with some rattle can primer to seal it up against corrosion, and let it ride. Here is the end result, with a fresh rivet:
I also learned that the washer should go on the nut side of my HS-411PP and that I should torque it to roughly 25 inch/lbs. I ended up buying this torque wrench so that I can read what the torque is from the nylon lock nut, and then add that to my final torque value: http://amzn.to/2gl2Axd
Once the wrench gets here, I will torque down the AN3 bolts and apply some torque seal (also on the way). Here is the photos from what little work I did today: https://goo.gl/photos/kxhRmW3LXQTkWas9A
Lynn Dixon
RV-7 Slider -
Old 12-01-2016, 11:50 PM
CubedRoot's Avatar
Default November 26th, 2016. 2.5 hours
My torque wrench hasn't shown up yet, so I wasn't able to finish up the last steps on the rear spar. I decided to continue on to the front spar and return to the rear once I get my wrench and can torque those 4 last bolts to the proper specs. The next step in the plans is to rivet the front spar assembly.
I started out by clecoing HS-710, HS-714, and HS-00001 onto the HS-702 front spar, so I could make sure everything lines up correctly before riveting.
The plans call for a AN470AD4-7 rivet where the HS-710 and HS-714 go together with the HS-702 front spar and the HS-00001 doubler plate. There are also a few location where you do not want to rivet, because the HS-000005 and HS-00006 ribs will attach later, as well as the holes that will be drilled later when the tail is attached to the fuselage. To keep myself from sticking a rivet in those holes, I covered them with masking tape. The only photo I have of my masking tape is from AFTER driving the rivet.
I used my squeezer to drive all these rivets which made it super easy to get them correct. Once I drove all the longer -7 rivets, I moved on to drive the shorter AN470AD4-5 rivets where the HS-00001 doubler plate attaches to the HS-702 spar. These are shorter because they don't have to go through the thick spar reinforcement bars. You can see the two rows of these rivets in the middle of the spar in the photo above.
The next step was to rivet the 4 flush head rivets into the HS-702 to HS-710 / HS-714 reinforcement bars. I had previously countersunk the bars, and dimpled the spar, so these 4 were easy to set with the squeezer.
After squeezing those last 4 flush head rivets, my front spar assembly was completed. I am pretty happy with the way it came out. I didn't have to drill out any rivets, and I made sure they were all set correctly by measuring each and every one with the rivet gauge. This is how it looked once it was all done and completed. I removed the masking tape since it's not going to be needed anymore.
Here is a link to all the photos I took for this work session: https://goo.gl/photos/Swd5BBf6HfW5jP2h9
Lynn Dixon
RV-7 Slider -
Old 12-01-2016, 11:53 PM
CubedRoot's Avatar
Default November 27th, 2016. 1.25 hours
I didnít have much time tonight, I was working on my parade car most of the day. But, I did find a little over an hour to get some work done on the airplane. My beam torque wrench was delivered today, so I also torqued the bolts that hold the HS-411 hinge bracket to the rear spar. Referring to the chart in the Vanís manual, I am supposed to torque the AN3 bolts down to 20-25 inch pounds, adding in the torque required to turn the nylon lock nuts. My beam wrench was showing 5-8 inch pounds required to turn the nylon nut on the AN3 bolt, so I figured I would torque the bolts down to a total of 28-30 inch pounds. After torquing the nuts down, I marked them with an ďXĒ using a sharpie. I will apply some torque seal once it gets here. This way I know which bolts have been torqued.
Having completed that, I figured I should go ahead and dimple the right horizontal stabilizer skin, since I had a little bit of time left for the night. I used my DRDT-2 dimpler to do the work, and it went smoothly. I already had the dimpler set up from last nights work, so I just popped in the sets, and went at it. I also remembered to mask off the holes in the skin that do not need dimpling, since they will be getting nut plates. The skin turned out well.
I spent a few minutes tinkering around with the pressure settings on my rivet gun. I will be riveting the ribs to the skins in a few sessions, so I want to make sure I have everything set right. I think I might spend some more time on the practice kits doing flush rivets over again. This will give me some more practice, as well as let me fine tune my rivet gun for the -3 flush rivets.
Here is a full photo album of tonights work: https://goo.gl/photos/upb27wsi3J5HnDuu5
Hours Worked: 1.25
Lynn Dixon
RV-7 Slider -
Old 12-01-2016, 11:57 PM
CubedRoot's Avatar
Default November 27th, 2016. 2.5 hours
After riveting the front spar, I was still wanting something to do, but nothing very involved. I realized I hadnít dimpled my skins yet, since I was waiting to do that until after the primer had cured. Since the next step in the plans call for me to rivet on a few ribs to the left skin, I figured this was just a good a time as any to start!
I used the DRDT-2 dimpling tool to dimple all my skins. I used a piece of scrap aluminum to set the dimple dies and the compression on the dimpler to form a perfect skin dimple. A lot of folks donít do this step since, and just go right to dimpling. Thereís nothing wrong with doing that, but there is an issue of under-dimpling which causes the skin to look like it has a ďdished inĒ surface around the dimple. You end up with this weird wavy looking skin surface. Again, theres probably nothing wrong with have an under dimpled skin, so long as the part fit together snug, but I am wanting to build a quality airplane that looks excellent, so I take the extra time to set these things. After a few test dimples in my test coupons of aluminum, I started on my left horizontal stabilizer.
The DRDT-2 makes this work a breeze! I still need to get some carpet or moving blankets so that I donít have to worry about my work surface scratching my skins. Right now I am using the plans manual under the skin to keep it off the rough work bench. It works, but not ideal. It takes a good bit of pressure to get a solid, clean dimple. I am also using spring-back dimple dies from Cleaveland tool and they need a good bit of pressure to form a good dimple. I spent about an hour going around the skin bottom. Then I marked off the top side of the skin using masking tape. There are a few rivet holes that will be used later on to install the tail fairing, and we use nutplates for that. So, Vanís has you not dimple a few holes in the top skin. I covered them with masking tape so I wouldnít accidently dimple them.
This process went pretty quickly because of the dimpler. I did have a few tricky holes towards the leading edge of the skin (where it curves/wraps around). I had to take the skin off the table, and hold it with the opposite hanging down in front of the dimpler so I could reach them. All in all, I think the dimples came out great. I test fit them with a spare AN426AD-3-4 rivet, and the rivet fits in perfectly and there is no wavy-ness or under dimpled holes.
Since I wonít be working on the right skin for a few more work sessions, I figured it was time to stop. It was also close to 1:15 AM, and I was a little tired by this point. Iíve always heard its good to stop before you get tired, because you will make a mistake.
Heres all the photos from tonights work session: https://goo.gl/photos/8H9dqyZWPKZR22A77
Hours Worked: 1.0
Lynn Dixon
RV-7 Slider -
Old 12-02-2016, 12:04 AM
CubedRoot's Avatar
Default November 29th, 2016. 3.25 hours
Tonight started off by riveting the HS-00005 and HS-00006 ribs to the HS-702 front spar. I was able to use my squeezer to set these rivets, but only just barely! I had to do some finagling around the front spar support bars, especially the larger HS-714 to get the squeezer to line up on the rivet heads. I did have to insert two rivets in the opposite direction in order to set them, but other than being cosmetic it wonít hurt anything.
After completing the front spar, I moved on to the left HS-601PP skin. The plans have a unique way of final assembly, and after reading over the plans, and visualizing what would take place, I dived in. This method is a bit different than the George Orndorf method I watched in his videos, but I am not using a RV-6 jig.
It starts off my clecoing HS-707 nose rib to the skin and then riveting it. After making sure everything looked good and flush, I riveted the rib to the skin. This was the first official piece of work that I riveted that would be seen from the outside, so I went slow and took my time. I was happy with the results!
And this was the first ever flush rivet to be set!
After riveting on the HS-707 nose rib to the top skin, the plans have me cleco the end rib, HS-706, to the skin, as well as HS-708 to help hold everything tight. This makes riveting HS-707 to the bottom of the skin much easier. HS-707 nose rib was a tricky part to rivet! I messed up two rivets so I had to drill them out and replace them after I got all the other rivets done. I have practiced this on scrap material a bunch of times, so it was no biggie.
And voila! You canít even tell it was fixed:
Once I had both sides of HS-707 nose rib riveted and done, the next step was to insert the front spar assembly so I can be riveted in place. So I got it all situated, and made sure everything was lined up and clecoed every hole to hold it in position. Once the front spar was fastened, the plans have you use a blind rivet (pop rivet) to hold HS-707 nose rib to HS-702 front spar and HS-708 middle rib. These rivets were a little tricky because the space is pretty tight and I have big ole gorilla hands. Not to mention the head of my pop rivet squeezer barely fit between the rib and the rivet mandrel. But, after some patience and a little wiggling, I was able to fully seat the three blind rivets that holds those two ribs to the front spart assembly.
As a side note, I learned from the Vans Airforce Forums that a good trick to protect your skins during riveting is to wrap your bucking bar in athletic tape, except for the tiny bit you are using against the rivet tail. This is a really good suggestion, because it helps you hold on to the heavy bucking bar, AND protects the primed surfaces from getting scratched up from the sharp edges. Since the athletic tape doesnt stick to anything but itself, it leaves no residue on the bucking bar!
Thats all for tonight. A little over 3 hours of work and I have my left horizontal stabilizer partially riveted and ready to finish up. I will leave the other work for another session when I am a bit more refreshed and ready.
Here is an album of all the photos, some showing better detail of the work: https://goo.gl/photos/KbJZJgAqgg6pmFCt8
Hours Worked: 3.25
Lynn Dixon
RV-7 Slider -
Old 12-02-2016, 12:11 AM
CubedRoot's Avatar
Default December 1st, 2016. 3.5 Hours
I spent about 3.5 hours on riveting the horizontal stabilizer, and ended up getting the left side completed, and ready for the rear spar. I also got a start on the right side and have it ready for final riveting.
First off I riveted the HS-706 to the front spar HS702 using universal head rivets. These were quick and easy:
The skin riveting work started out by riveting the ret of the skin to the skeleton, on both sides. George Orndorf suggests riveting from where the HS-707 and HS-708 meet at the front spar (HS-702), and then working your way outward from that center point. This helps to reduce any oil-canning that may occur and its also a lot easier to do. So, I started out at that junction but using an AN4263-4 rivet. The -4 length is needed here because the ribs, spar and skin are all riveted together. The plans calls for an AN4263-3.5 rivet everywhere else on the skin. Here is where I first started riveting:
These came out pretty great and I checked each one using a rivet gauge to make sure I was setting correctly. Then I just continued radiating outward from that center point, working left-right-center in order until I reached the edges. I am happy with the results, there was no denting, dishing or smiles! Looks smooth and flush:
And here are a few shots of the completed left horizontal stabilizer, inside and out:
After I finished up the left stabilizer, I had some time left so I moved on to starting the right horizontal stabilizer. Its done exactly the same as the left, so I followed the plans like I did last time. I clecoíd HS-707 nose rib to the skin and then riveted it to the top skin. Then I used HS-708 and HS-706 to hold the skin in place with clecos while I riveted HS-707 to the bottom skin. Then I pulled HS-708 out and inserted the HS-702 front spar assembly. Now this thing is starting to look like an empennage!
After getting both sides of the right stabilizer clecoed in place to keep any undue stress from the skeleton, I called it a night. I will rivet this skin to the skeleton as well as HS-706 to HS-702 in the next work session.
Here is all the photos from tonights work: https://goo.gl/photos/GxeabPSKq5DGGumt9
Hours Worked: 3.5
Lynn Dixon
RV-7 Slider -
Old 12-02-2016, 12:16 AM
CubedRoot's Avatar
I just updated this build log with some entries I had saved up on my website. I have started putting them there first, and then I will copy them to over here. These last 4 or 5 posts were all individual work sessions that I had not logged n here yet, so I updated them all.
As of right now in summary:
  • Left horizontal Stabilizer has been riveted to the skeleton, will wait on the rear spar and edge rivets until an EAA tech counselor has a chance to look it over.
  • I started on the right horizontal stabilizer tonight, and it is ready to be riveted to the skeleton this weekend.
  • Vertical Stabilizer primed and ready to be assembled and riveted.
  • Total hours so far: 59.75
  • Total Hours spent priming (included in the total hours): 5.25
Lynn Dixon
RV-7 Slider -
Old 12-03-2016, 12:06 AM
CubedRoot's Avatar
Default December 2nd, 2016. 1.5 Hours
Tonight I spent about 1.5 hours on riveting the right horizontal stabilizer. I am very close to getting these skins riveted on, and almost to the point of attaching the rear spar. I have decided to wait on attaching the rear spar until I can get an EAA Tech Counselor out to take a look at my work to see if I am on the right track, and that my rivets are looking OK.
I started this work session off my attaching HS-708 center rib, to HS-702 front spar and HS-707 nose rib using LP4-3 blind rivets. From doing this on the left side, I knew it was going to be tight, so I took my time and got them set. My hands were almost to large to work the pop rivet gun in that little space!
Next up was to rivet in the AN470AD4-4 rivets that attach the HS-706 end rib to the HS-702 front spar. These rivets set OK, but I did let the rivet gun jump a little and scratch my primer. Luckily it didnít do any damage to the end rib other than cosmetic primer.
Then it was time to do the bulk of the work: Riveting HS-601pp to HS-702 and HS-708. Like on the left stab, I worked from the center outward to eliminate any oil-canning, and made sure to insert the single AN426AD3-4 rivet into the hole where HS-601pp (skin), HS-702 and Hs-708 meet. Once that guy was set, the rest of the rivets were AN426AD3-3.5. This turned out pretty well, and I didnít have any dishing or denting. I also checked the rivets with a rivet gauge to make sure they were set correctly. I am finding that my ďearĒ is getting used to the sound of a correctly set rivet, and I am getting them at the perfect depth almost every time. Here is how the skin turned out:
I completed the whole bottom side of the right stab skin tonight. After setting those rivets, my left arm was pretty beat from holding that bucking bar, so I decided it best to quite for the night before I messed up that pretty skin. I will finish up the top side tomorrow, and that will have the skins riveted, save for the HS-00005, HS-00006 ribs and rear spar, which I will hold off on so that the Tech Counselor will be able to look inside the stabís to inspect.
Hereís all the photos from tonights work: https://goo.gl/photos/k3pWa5Hoduz2MCyf7
Hours Worked: 1.5
Lynn Dixon
RV-7 Slider -
