Thanks for the challenge but I do have some facts
Geico266 said:
Over voltage of the "unprotected" alternator cost me $1,000. A freind of mine just spent $2,500 repairing his "urban myth". Overblown? The extra money you spend on a OV protected alt is CHEAP insurance for your electrical system.
YOU LEFT OUT ALL THE DETAILS. I bet it was a external voltage regulator? That's the problem with the rumors. Are you talking ND alternator? What vintage of radios died? What was damaged? This is good info, so please tell all of us more. Keep in mind this is all about internally Regulated Alternators I-VR, ND's specifically.
Geico266 said:
You state most electronics can handle 18 - 60 volts? Not the new experimental stuff guys are installing in homebuilts. Dynons, Blue Mountain, Garmin handhelds.
That is not true
I called Dynon, their voltage range is as I said 10-30 volts and 60 volts peak. Also I asked Dynon if you had a super nova OV, what would be damaged and what would the cost of repair be? They said the repair would be small, because there is protection to the main circuits!
Garmin, they are made to 1-30 volts, I am reading the manual right now, for a HANDHELD Garmin 195. Operating voltage 10-30 volts. Surge? If its has a regulated power supply it probably can take spikes.
Blue Mountain? I don't know but if they don't have a regulated power supply I would be surprised. If they did not work with a wide voltage range and surge protected I would not buy it frankly.
YOU BRING UP A GOOD POINT. Not all radios are made to this 10-32 volt / 60 volt surge standard. Old radios most likely to not have OV protection, but some new ones don't.
My ICOM A200 com radio is NOT protected. The max for the ICOM is 16 v (according to the manual). I called ICOM and ASKED WHY? They said that is the way it is. I could put a "Transorb" on the CB to protect just the ICOM?
My OLD Collins TDR950 transponder is not protected for 30 volts. I called Collins (now S-tec, a Miggitt co). They don't make TDR950s any more, but I asked a technical guy what damage these transponders get. He said an OV can cause damage but it's usually limited to a few semiconductors on the board.
I would say if YOU did have $100,000 worth of avionics made to 1970's standards I would be more worried about OV.
Geico266 said:
While it might not kill these items, you still need to send them back to the factory or avionics shop for repairs. Blown internal fuses, cooked display screens, burned out / weakened Optima & Concord batteries. Big bucks and a long down times, both easily avoided with OV protection.
I can't say what happened to you, but guess it was with a Cessna, Piper or Beech and not a ND alternator and modern avionics? You are right OV is NOT good. If your radios or GLASS burn up at 16 or even 18 volts, it's not aerospace quality, at least by today's standards.
Geico266 said:
Not to mention the possibility of an in flight electrical fire.
Sir I don't mean to be condescending, and I am not very diplomatic. You need to take a deep breath. I might say PROVE IT! What is going to catch on fire? What case have you seen where a ND I-VR caused a fire? There are fires and electrical ones but none involving ND alternators I know of.
I researched this on the "National Highway Traffic Safety Administration's" (NHTSA) data base. NHTSA's data base has ALL auto/truck consumer complaints, manufacturer's service bulletins, letters, trouble reports and recalls. I looked at ALL issues with electrical fires, alternator fires, alternator reliability and spacifically Nippon Denso. There where no alternator fires, induced fires or recalls with the ND brand.
ND has no history of any problems in millions and millions of vehicles and decades of service.
There where electrical fires (Ford). There where alternator problems (Hitachi and Ford). The electrical fires associated with alternators usually was the result of something being close, touching the alternator and catching on fire. Faulty wiring or bad connector plugs where also a big problem.
High voltage will not melt the wire, power will. A short to ground on a hot wire will cause the amps to go to infinity. That is bad. The wiring on a 28 volt plane is the same, actually it can be smaller than a 14 volt plane.
The propaganda got out of hand for awhile on I-VR alternators. They are designed to work with OUT add-on OV garbage. The risk is small. The worst case scenario survivable. To avoid fire, keep things away from the alternator, wire it properly and make sure no oil is dripping on it. (no kidding)
Geico266 said:
If you would like to talk to the people involved in the incidents I mentioned so you can continue your "myth busting" PM me and I'll supply you with the names and cities they live in.
By all means Sir, please lets get the facts out. Lets get the details, RV model, ND alternator model, what happened. Details, details, details, the devils in the details.
I can tell you about 5 cases in planes and 1 in a car where a ND went a little wacky with voltage. I first tell you about the worst two:
Flying a pilot decided to turn the alternator OFF and back ON in for no reason. (Guys STOP that) As soon as he turned it back on the voltage went way high. He turned the alternator back off with the ALT switch. No damage except the alternator, that he had rebuilt. He did not say how high it got because he did not look, just that it was high.
A new alternator , 55/60 amp ND, was installed. During the next flight he smelled something. Down wind of a factory, he ignored it and continued to fly (10-30 min more?). The smell was worse and he finally noticed the voltage was high. This Gent turned the alternator off with the ALT switch, and it responded. There was battery damage (Odyssey). The battery did not leak but was puffed out. The Odyssey battery should not be subject to over 15 volts for extended periods (per the manual). There was no radio damage reported. [Clearly an OV light would have solved the problem. The max voltage was 15 volts (my guess).]
In the cases where the alternator was shut down with the ALT switch, I'd say don't always count on it. That is why I like the CB on the panel. The lesson is have a OV warning light and don't cycle the ALT switch with the engine running. The other cases of OV where mild and basically the voltage was not stable, going up/down with RPM and load, but max Volts where mild.
My RV4's ND had 1000 hours with no problems before I sold the plane. Another guy had the same experience, but the brushes went at 800 hours. It's still going strong. Both of my Acura's with lots of miles and years, both with ND's are still working great.
I've asked Nuckolls and others about their stories. Bob said some guy in a Lancair had $100,000 in damage with a ND alternator? I asked for details: data, time, place, equipment, narrative, analysis or ANY THING; I got nothing but "well I did not see it but I heard." I think it turned out to be a B&C alternator!
Geico266 said:
I'm not an electronics guy by any means. All I know is the bill, and down time I had to deal with when my alternator failed to full power. Never again for my ship.
OV is COMMON! Happens! BUT...... with 1960's and 70's aircraft alternators and regulators, because those OLD externally regulated alternators are crude they need OV protection. Old planes used old autolite, prestolite, motorola, delco auto parts from 1960's Ford's, Chrysler's and Chevy's.
Geico266 said:
JMHO & $.02 worth, do what you want.
I appreciate a challenge. Let me know what happened to you. If you want belt and suspenders on your ND alternator I suggest PLANE POWER.
