Every once in a while while landing, I get a strange nosewheel action. I have tried a number of techniques, but I can't figure out what I am doing wrong or what is going on. Here's the situation.
I come in and flare. Normal landing speed. Actual speed doesn't seem to make much difference as I have tried different speeds. What happens is that when I hold the stick in my gut, and the nose finally comes down on its own, it appears as if the nosewheel is all the way to one side. It vibrates a lot, like it is stuck over to one side. Sometimes, it feels like it is being thrown to one side. I called Van's and they thought I had the friction nut too tight. My old plans called for a break out force of 28 lbs. They suggested 22 lbs. This did not change anything. Keep in mind that I cannot figure out how to make it do this. It just does it some times. Another suggestion I had from a GlassAir guy was that he had a similar problem and raising the tire pressure up cured the problem. I tried that also, and it appears to help some, but not totally.
Has anyone else experienced such a problem or heard of such a situation? If so, I would like any suggestions. It may be my technique, I just don't know. Any help would be appreciated. thanks.
Roger
Roger
