On step 3 where you bolt the Elevator Idler Arm Assembly to the Idler Arm Brackets. I have all 6 washers (3 each side) on with the bolt through and it's a really tight fit. So tight that the Idler Arm assembly drags against the brackets. Should I remove it and take a 1/16th or so off the flange on the assembly, or use more washers to space it a bit more or is there something I'm missing?
