Old 08-25-2016, 09:42 AM
boomer's Avatar
boomer boomer is offline
Default Lycoming SB 518D Oil Bypass Valve Inspection
Has anyone checked SB 518D ( http://lycoming.com/Portals/0/techpu...Inspection.pdf ) to see if it applies to the IO-360-M1B? Thanks.
-John
John Banister
RV-8 Engine (IO-360), Prop (CS)
Flying Since Aug, 2011
2017 Dues Paid
Old 08-25-2016, 01:51 PM
kai kai is offline
We had a Mooney with an IO-360 with an affected vernatherm. You should check which one you have installed.
Kai
flying RV-9a, O-320, G3X Touch
a father&son project
Old 08-25-2016, 02:17 PM
Bavafa Bavafa is offline
There is no instructions as where exactly this is located in our engines or how to remove them. Anybody has done this or has pictures of it.
I also have a IO-360-M1B but no indication if this part is in my engine or not.
Mehrdad
RV7A - IO360M1B - SOLD
Dues paid
Old 08-25-2016, 03:26 PM
bret's Avatar
bret bret is offline
mine is on the oil filter adapter, all you will see is the thin looking nut part between his pinkeye and ring finger, there should be safety wire on it. if you remove it, be sure to have a new copper sealing washer, it may or may not seal after removal.
2018 gladly supported
Old 08-25-2016, 03:49 PM
Yes, I found more info and it looks like the torque value is 300 in.-lbs. (34 Nm)
http://www.lycoming.com/Portals/0/te...eplacement.pdf
Mehrdad
Dues paid
Old 09-20-2016, 07:59 PM
Just wondering if any one has checked for this SB and found any issues. Also, any thing to watch or trick to know for when installing it back? I have ordered some washers and believe the torque value is 300 Inch and planning on doing this this weekend.
Mehrdad
Dues paid
Old 01-05-2017, 06:02 AM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Any more information on this?
Hello,
does anyone have more information about this? The link to the Lyco document does not work.
I'm interested in more information about which seal does it need, so I can organize a new one before I take it apart, and how much torque I need to install it. Looks like Bavafa found the torque which seams to be 300 in.-lbs.
Dominik
Old 01-05-2017, 07:48 AM
BillL BillL is offline
Originally Posted by swisseagle View Post
Hello,
Dominik
Parts are in parts book.
Torque is in overhaul manual.
The document is available on Lycoming.com.
It affects ALL 360 engines, so my new M1B is in range.
If I hit my finger with a hammer and someone else had the pain, I could keep doing it. Defective design, defective part, and we have to cover it. Nice business model for Lycoming.
Bill
Op Lims in hand 12-7-17
1st Flight 1-27-18
2017 Dues Paid
Old 01-05-2017, 09:46 AM
jdeas's Avatar
jdeas jdeas is offline
Hello,
Dominik
VERNATHERM GASKET - 76510 @ aircraftspruce.com
Get a few, this is a recurring inspection, or replace with a newer Vernatherm unit
JD
RV-7 N314SY
CANbus based trim/flaps and electrical
Old 01-05-2017, 09:48 AM
az_gila's Avatar
az_gila az_gila is offline
Hello,
Dominik
Correct new link for the original SB -
http://www.lycoming.com/sites/defaul...%20%281%29.pdf
The SB is part number dependent so you need to check what is on your engine.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
