Old 12-23-2016, 09:09 PM
Originally Posted by KeithB View Post
Nice panel Keith.
I am curious why you (and so many others) put the ELT control panel way over on the right side when with as small as it is it could easily be located somewhat directly in front of the pilot?
There could be a valid argument that it doesn't meet the TSO requirement for the installation of "in plain view of the pilot".
Another reason I wont locate them there is to avoid a curious passenger messing with it in flight and possibly activating it without the pilot noticing.
The last reason is that from my experience, the highest failure item with the ELT system is the G switch. I have replaced a lot of ELT's because they failed the yearly activation test.
If I am ever in a forced landing situation, I will manually activate the ELT rather than rely on it self activating if needed.
Because of this I want it easy to access.
Not meaning to judge....
Just seriously curious what makes so many people locate them almost out of reach.
Scott McDaniels
Hubbard, Oregon
Old 12-23-2016, 11:28 PM
KeithB KeithB is offline
Scott:
I don't have a good answer for you, as your points are valid. It could just have easily been above my G5. I have always thought about it as a device I don't need to access except for testing (or failure) so I wanted it out of prime real estate. Perhaps I'm victim to bias (many other panels including the RV-6A I'm currently flying have it on the far right). Or maybe it's because it is the most dated item on the panel (not been updated, not very ergonomically/esthetically designed as it is either very recessed as I have it mounted or very protruding if front mounted) and I don't want to look at it. Or maybe I naively believe it will never be used (passively or actively).
I can say that the only time I have used one was in my RV-6A when it went off by mechanical fault, I knew it through my headset, and we flew with my passenger pressing the reset button continuously for 25 minutes to silence it until we landed and disabled it. In that case, I was glad it was on the passenger side, but that's a pretty unusual case.
No good answer for you. ( I am okay with the CO detector on the far right as I have it connected to the G3X).
Keith Brown
RV-14A Builder - kit #136, XP-400 Aero Sport Power
N314KC - First flight Mar 8, 2017, >400 hrs
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 12/2018
Old 01-30-2017, 09:00 PM
RVmaniac RVmaniac is offline
Is the inclusion of a second g3x screen more or less for aesthetics? Being on the passenger side it seems kind of out of the way and difficult to manage let alone see. Besides the fact a single g3x provides all the instrumentation you need most panel shots I see always depict the 2nd screen as just displaying the same info as the primary. Like literally just displaying engine information and using the same moving map as the PFD or fancy IFR screen.
I get the feeling the dual screen setup was popularized by Cirrus, and in their case it makes sense as the input panels are all located on a center stack below the screens somewhat like a car. Making a plane look like a lexus was a big part of cirrus's design philosophy, and they make good use of the dual screen setup by having each one run in full screen mode for their intended purpose. PFD is for instruments, MFD is for nav and it works well. But in all of these RV dual screen setups it seems like the 2nd screen will never really be used for anything. Between split screen mode on the G3X and just having your center stack occupied with your input panel the 2nd screen is just off in the distance doing nothing.
Thoughts?
Old 01-30-2017, 10:00 PM
Tom023 Tom023 is online now
A few reasons I can think of are:
- So the plane can be flown from the right for training purposes; I actually prefer flying from the right
- Inclusion of the passenger in the flight and flight processes
- Redundancy in case the left display has a failure
- For those with 20/10 vision like my son, he can actually read the right display from the left
- So I don't have the passenger constantly leaning over me to see what is on the display, which can be both a safety issue and plain, and plane, annoying
What puzzles me more is why some locate the backup attitude display to the right of the right screen.
I'm sure others will chime in.
RV14A #140083
Down to last 5%.
2018 Donation
Old 01-30-2017, 10:05 PM
In my case, my usual co-pilot/passenger is an active navigator and planner (though not a pilot). Not only will the 2nd screen make flying more enjoyable for her, she will be able to check everything out (route, WX, stops, etc.) without touching my screen, but she will help with navigation and flight plan changes.
Plus, I get redundancy if needed - in an emergency that 2nd screen will be quite valuable, and way easier to see than no screen at all :-). Others will have different reasons I'm sure.
Keith Brown
RV-6A sold
Dues paid 12/2018
Old 01-31-2017, 12:13 AM
ok so the left seat is not actively using the screen under most circumstances, it's just a small added fee "just in case" (and lets be honest, a little bit of wow factor ). I'm fine with that, just wasnt sure how ergonomic it would be for use as a MFD.
Old 01-31-2017, 02:39 PM
jswareiv jswareiv is offline
Default Second Screen
I actually had this happen to me last weekend. My PFD went out and I flipped the switch under the MFD to be used as a PFD. Garmin is swapping it out for a new one.
I originally did it to help others learn to fly from the right, but it sure came in handy. I use it all the time in regular flight though. When ATC tells me there is an aircraft in my vicinity, I flip to the traffic screen to find it if I don't see it out the window and it gives me a great idea of where they are. I will leave it on weather if the weather is bad, or if I am looking at the map on the PFD, I will use the sectional view on the MFD. It's also nice to have when taxiing at a strange airport, flying a procedure, etc. I love having the second screen. I also have another backup, GRT Mini, which is totally separate, but it's small and I like the bigger display if I have it.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW
Old 02-01-2017, 05:36 AM
Ok thanks guys, sounds like most of you use the MFD as more of a backup than anything else. I suppose it would see more use in flight if the screens were directly adjacent to each other but it appears as though the panel mounts for the 14 do not allow this, at least not if you want to make changes potentially compromising the airframe somehow.
Old 02-01-2017, 05:48 AM
control control is offline
I think you exaggerate the problem of viewing the screen on the other side.
I am now beginning my seventh season as an instructor, I have no problem flying from the right seat even if the AC only has a six-pack on the left side... Sure I would like to have it in front of me in IMC and turbulence but as I backup solution I think it is fully adequate to have a symmetric panel.
RV-14 kit #140138
I have entered the 90% done, 90% left to do zone
Http://magnusrv.blogspot.se
Old 03-13-2017, 05:14 PM
frghtdg frghtdg is offline
Just installed advance VFR panel by Stein.
Perfect.
Hank
N14HN Phase 1
140268
B744
Sailplane Racing
Dues
