Old 05-03-2016, 07:41 PM
Default FlightCom 403 Intercom Quit Working...
The FlightCom 403 in my RV-12 quit working. I removed the unit from the panel and heard something loose inside. I took off the top cover plate and discovered a nut and insulator bushing the holds a power transistor heatsink vibrated loose and fell on the circuit board. The remaining screw without its insulator allowed the power transistor to short-circuit against the metal case. The real problem is when the 403 quits working it prevents audio from the comm radio to reach the headsets.
A new (used) 403 is now on order and I will remove the top cover plate and put some adhesive on the exposed thread to prevent recurrence.
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-03-2016, 10:02 PM
Harvey rv12 Harvey rv12 is offline
Wow, great diagnosis!, to bad it fried the board.
Where did you find the used one?.
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 05-03-2016, 10:15 PM
eBay - $90.00 shipped
Hinckley, Ohio
EAA #499867
Old 05-03-2016, 10:33 PM
The only time I ever lost comms was when my alternator and battery went out on my Cherokee. Naturally it was the one time I had left my portable comm at home. I shut off everything but the XPDR and had enough juice to squawk 7600 and fortunately got a steady green from the tower. Fortunate because I pretty much forgot all the other light signals! When selecting 7600 I inadvertently went thru 7500 which woke up the boys in PHX TRACON.
