FORANE
From the Navworx ADS600-EXP install manual:
The UAT Antenna MUST be installed no less than 5 feet from any L-Band (Transponder, TCAS, TAS) antenna. Failure to adhere to this critical installation note will result in failure of the ADS600-EXP and void your warranty.
ok, I can separate the UAT antenna from the transponder antenna, no problem.
I do not have TCAS.
TAS antenna is Traffic Advisory Systems (TAS). I don't think I have this. Does a Garmin GDL-39 count?
Now, the wild card, according to wikipedia L band antennas include GPS:
https://en.wikipedia.org/wiki/L_band
The Global Positioning System carriers are in the L band, centered at 1176.45 MHz (L5), 1227.60 MHz (L2), 1381.05 MHz (L3), and 1575.42 MHz (L1) frequencies.
Does the UAT antenna need to be separated from GPS antennas also?
I do not have TCAS.
