Old 03-10-2016, 12:00 PM
kentlik's Avatar
kentlik kentlik is offline
Default RV-7A rebirthing
So I started the long process of unbending my -7A...
Going to be a long road, but worth the effort.
She went down in Nevada, moved to CA, now based in Portland OR.
Not much straight on her but she is resting comfortably...
Started the removal process and it is not bad, at least the easy to reach rivets aren't.
Will keep you posted on what I uncover deeper into her innards
Kentlik
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 03-10-2016, 01:57 PM
flyboy1963's Avatar
flyboy1963 flyboy1963 is online now
Default talk about an 'edyoocayshun!'
Kent, you'll know more than most A&P's by the time you're done!
...and no doubt have mined the brain trust here more than a few times!
good luck with the re-build!....we'd like to know the rest of the story!
( a harmless little stunt gone astray?????)
Perry Y.
RV-9a - SOLD!....
kinda missing it!
Lake Country, BC
....paid up til Nov. 2018
Old 03-10-2016, 03:39 PM
jbDC9 jbDC9 is offline
This thread from 2 months ago should explain the background on this project...
http://www.vansairforce.com/communit...d.php?t=133682
John Bixby
RV-8 QB sn 82030 - 1475 hrs
O-360-A1D/CS/Pmags
New Waverly, TX
VAF donation Dec 2017
Old 03-10-2016, 05:01 PM
acam37's Avatar
acam37 acam37 is offline
Please keep us updated on your project. I went through the same process with my RV-4. 2-1/2 years from picking it up in Ohio to liftoff.
Arlie Conner
RV-4 (N124TT) Sold
RV-8 (N269CP) Sold
RV-4 (N684ML) under construction
KOCH Nacogdoches
Old 03-10-2016, 07:01 PM
KatieB's Avatar
KatieB KatieB is offline
Drilling out rivets to pull off the bent and broken bits is like carefully unwrapping a birthday present. (At least, it is when the major structure beneath is OK!) At some point, you get to the undamaged core and then it isn't broken anymore, it's just unfinished. Good luck! This sort of project is very rewarding.
Katie Bosman Krotje
Sold my RV-3B project...
Build log
But RV8 3301 is in the works.
Jabiru J200 flying
Old 03-10-2016, 07:51 PM
Blain's Avatar
Blain Blain is offline
Thumbs up The journey begins...
Good to see the process started, Kent.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 03-10-2016, 07:59 PM
cajunwings cajunwings is offline
Default Repair
Kent: I'm a couple years into a 9A rebuild project. Mine was damaged in a nose over at fairly low speed. Since you are not building the kit in the normal sequence you will find yourself having to jump around in the build manual and at times get creative accomplishing tasks that aren't in the usual build. Feel free to contact me.
Don Broussard A&P, IA
RV9 Rebuild in Progress
Old 03-10-2016, 08:45 PM
kentlik's Avatar
Thanks Katie!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 03-11-2016, 05:45 AM
BSwayze's Avatar
BSwayze BSwayze is offline
Kent,
It was great meeting you at the pancake breakfast and chatting a bit about your project! Anything I can do to help, please just let me know. It will be fascinating to watch your progress and see how this turns out for you. Please post lots of updates and pictures here for everyone!
One suggestion, since you're drilling out LOTS of rivets... a slower drill may be better for this task than the faster one. You probably know that already, but I thought I'd mention it. I actually turn the chuck by hand a few turns at first to make sure the bit is centered in the rivet head and gets a good "bite" before putting the slow power to it.
Bruce Swayze
RV-7A Standard Build
Working on Wiring and Panel!
Dues Proudly Paid for 2016
http://www.BrucesRV7A.com
Old 03-11-2016, 10:01 AM
JonJay's Avatar
JonJay JonJay is offline
Good luck with your project Kent.
If you need any aluminum sheet, let me know.
Currently my surplus is in .025 2024 T3
I sell it to VAF'rs and friends for 10% off of the lowest price you can find from Spruce or Airparts.
Local pick up only. Cash. Battleground WA.
They are full sheets, 4'x12' that can be rolled. I can also cut to size if you don't get too crazy. I have been hesitant to post to VAF yet as, until today, I didn't have the stomp shear needed to deal with it and my forklift was out of operation. All good now.
This same offer for sheet is available to any local VAF'rs. I am not set up to ship, so local pick up only. I am not interested in selling the lot. This is a favor for the local RV community, not a money making venture.
I don't think DR would disapprove.
I purchased a huge lot of surplus sheet several years ago for my Fiat G.46 projects and I have way more .025 than I need.
There may be some slight edge damage to some sheets. However, thus far, the sheets that I have pulled out of the stack have been perfect.
PS - I have removed thousands of rivets. Sounds like you are becoming an expert too, but if you want a quick lesson or compare technique, let me know. Happy to help.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
