The best RV
Van was asked at Oshkosh what the best RV was, RV -4, -6, -7, -8? He said without a doubt, the RV-3. Ouch
From many a stand point, I can see what he means. I have flown the -4, -6 and now building a RV-7. They all fly nice. Build it light, clean and have fun. As far as speed, fuel economy, aerobatics it is up to you. I think most people think, at least I do, the RV-9 is less "hot". What does that mean? Van calls it more "relaxed". The RV-9 has a lower stall speed for one.
I think people have and continue to get into problems with RV's because they don't fly them at proper speed and do get into higher sink rates. Why? (experience, currency) The RV-X is not hard to land if you fly it on the numbers. I have almost 1000 hours in RVs (all tail draggers). They are easy to land. Is the RV-9 impervious to landing problems? No, you can still stall it or land hard, bounce or loose directional control with a -9, as much as any RV, no doubt, but it may be just a little easier to land. For many pilots that is a factor. Nothing wrong with that.
The -9 is basically a -7 fuselage with a different wing and stab. It has more wing area and was the first time Van departed from using the tried-n-true NACA 23013.5 airfoil he always used. This NACA airfoil goes way back, is one of the best around, used in countless famous well regarded past airplanes and continues to kick the butt of many newer Johnny come lately fancy airfoils. In the 80's laminar flow and GA airfoils were suppose to be like magic, with huge gains in performance; they looked good in the wind tunnel, but they did not deliver in the real word. Well the airfoil on the RV-9 is obviously doing its job, at least within this power loading, wing area, wing loading, span and aspect ratio. Clearly it has low drag in cruise, low stall speed and I am guessing a docile stall characteristic. Not a leap in performance but a tweak, for spacific reasons. Nuff said. What about the NACA 23013.5 airfoil? Well RVs are one of the most popular homebuilts with thousands flying, with wonderful handling qualities, that fly fast but still have low stall speed. Nuff Said. They are all good, but there is no free lunch. Notice the RV-9s new airfoil top speed about is about 5mph slower than the RV-7 (160HP), which is the about the same differnce in stall speed, 44 mph vs. 51 mph. Again no free lunch, gain low end loose top end.
In light airplane designs there are compromises and all RVs have a good balance. You can tweak it a little one way or another but there is no quantum leap. That is what Van did, tweak. Why carry a 9 g spar around in an airplane that is only going to do straight and level. Why have less wing area, when a little more will get lower stall at with only a small loss of top end (with a new airfoil)? Van has tweaked the airframe, not redesigned it. A RV-9 is a RV, Nuff said.
Most of these debates come from a builders choice, who wants or needs the advantage one design has over another, like slider vs tip up, but they do not want to admit or accept the compramise of that design. No need to justify a decision, its all win-win. If you are not a hot acro / formation pilot or feel with your experience the RV-9 is a better match, than build that and don't worry about justifying the 5 mph at the top end, or the lower "G" limit. Who cares. If that is the way you fly; the RV-9 is more optimal for you. I like to do acro, formation flying and enjoy racing on occasion, so the RV-7 was my choice.
I liked the RV-6 and could have got one of the last QBs, but liked the RV-7 fuel, pre-punched parts and higher gross. Did not go RV-8 because I was tired of the tandam seating; on a long XC you can sperad out more if solo, and with a pax it is more fun to see the person you are talking to, IMHO.
(justification in progress
If I had a choice I would have 8000 sq ft hanger with a Pitts (or other hot acro plane), a Cessna Citation, a Turbine Beaver or Caravan on floats, a Super Cub on Tundra tires and a few RVs (-3, -8, -7, -10). Oh well, I guess I'll have to get by with one 180HP RV 7 and a small T-hanger.
George RV-4, building RV-7
