Old 10-28-2015, 03:10 AM
rdamazio's Avatar
rdamazio rdamazio is offline
Unhappy HS rear spar holes misaligned
Hi all.
I'm nearly done with my HS - riveted the rear spar to the skin on the top side without issues, riveted it to the bottom right side...and then the holes on the bottom left side have a slight misalignment
Even though the misalignment is less than 1/32", that's enough to make the rivets not go in straight:
I'm pretty sure I drilled these straight, and had no mishaps while riveting the ribs. I followed the instructions religiously.
Any suggestions on what to do here?
I assume using a drill to make the holes match again is a bad idea?
I tried putting a little force to make it align, but it only makes the skin start to bulge, so I stopped.
The other thing is that it's about 40degF colder today than when I drilled these - the metal wouldn't deform this much with such a small temperature variation, would it?
Thanks everyone in advance!
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
Old 10-28-2015, 07:24 AM
Jesse's Avatar
Jesse Jesse is offline
If you hold a couple of clecoed at and angle to help it along and squeeze one River, it often will pull and hold the parts aligned and the rest will be straight.
352-427-0285
jesse@saintaviation.com
Old 10-28-2015, 12:34 PM
rdamazio's Avatar
I tried that, but the skin doesn't move, just bulges :/
San Jose, CA
VAF dues paid
Old 10-28-2015, 01:35 PM
AviatorJ AviatorJ is offline
I literally just went though this last night. I laid the HS on it's side and started dropping rivets into place... several times I got to areas that were like in your picture and I couldn't put a rivet in there. What I found that if I started from the inner section and moved outward with the squeezer it pulled it enough to align everything back up.
Justin
RV-10 Quickbuild 'Final Assembly'
http://operationrv10.blogspot.com/
Donated for 2018
Old 10-28-2015, 02:44 PM
9GT's Avatar
9GT 9GT is offline
Get yourself a few tapered awls or machinist scribes. The work very well to line things up.
David C.
Howell, MI
"Donor Exempt" but donated through Dec. 2019
Old 10-28-2015, 07:00 PM
Richard Connell Richard Connell is offline
My HS 1003 spar had slipped on the punching machine so the outboard 20 or so holes wouldn't line up with the skin either. It was about the same misalignment - a little over 1/32. It was very clear where the offending hole was as they were exactly 1" centers then one that was 61/64 then back to 1" again.
But I noticed it at the drilling stage as I couldn't get the skin clecoed to the spar to match drill it in the first place. So I'm not sure if you have the same issue.
I required a new spar.
Van did point out that they punch 10 or so at a time on one sheet then shear it into 10 spars then bend the flanges. So it's possible there are more out there with the same issue.
Cheers
Richard
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 10-28-2015, 07:25 PM
spark68 spark68 is offline
Default opps rivets
How about drill to #30 and use opps rivets? Same head size, but larger shank.
Mark Curley
RV-6 (under construction)
dues paid 2019
Old 10-28-2015, 07:34 PM
N941WR's Avatar
N941WR N941WR is offline
Try to avoid using opps rivets at all cost. They can pull out over time. Using one in a line is OK but not a bunch of them. You are better off drilling them up one size and putting in larger rivets.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-28-2015, 10:34 PM
bwestfall bwestfall is offline
What about the oops rivet makes them pull out over time? Does the smaller machined head work it's way loose because of the larger diameter shank? I have not heard this before.
Ben Westfall
RV-10 (finish kit)
Coeur d'Alene, ID
Old 10-29-2015, 12:18 AM
rdamazio's Avatar
Thanks all for the suggestions, I managed to get this done, and my HS is now completed
The way I did it was similar to some of the suggestions above, but instead of an awl or cleco, I used a #40 dimple die I had, which better supported the hole instead of risking deforming one side - slowly used it on one hole to force the skin into alignment, then put the cleco on the next hole (rinse, repeat 31 times). I also bucked these rivets instead of squeezing to make sure they didn't bend.
San Jose, CA
VAF dues paid
