Steve Barnes
Went to move my RV6 in the hangar and one wheel had a point of very bad resistance while rolling. It would catch and let go while rolling it around. It felt like a disc was badly bent. Further inspection revealed that one of the three #4 bolts that hold the rim halves together was totally missing and the halves pulled away a little. (I know what you are thinking. NO I didn't forget to put it in). Somehow it must have broken and both parts of the bolt/nut were missing (probably at the bottom of someones swimming pool).
Here's my thoughts; I probably have under torqued the bolts thinking that the tire pressure would do that. If there was a little working room for the bolt/nut to move because of under torqueing it may have caused the nut to break at the threads.
Anybody else have this happen or any ideas.
Steve Barnes Owner of Fairings Etc.
