Old 09-04-2015, 01:05 PM
docrichardson docrichardson is offline
Default is it good to alternate rivets on rudder trailing edge?
Does is make sense to alternate the rivets on the leading edge of a control surface...in my case I'm building the rudder. I will use proseal to hold the parts together, with a strip of L bracket running the entire length, clecoed in, allowing a couple of days for drying before I rivet. Thanks for sharing your wisdom on this.
RV-9A build started August 2015
Sammamish, WA
Old 09-04-2015, 01:56 PM
Rupester Rupester is offline
Proseal on the leading edge or the trailing edge?
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 09-04-2015, 02:01 PM
Proseal only on the trailing edge...senior moment
Sammamish, WA
Old 09-04-2015, 02:20 PM
wirejock's Avatar
wirejock wirejock is offline
Default Rivets
Leave it clekoed to the straight edge for at least a week. Two would be even better.
The longer it sets the stronger the bond.
I don't think the rivets need to alternate. Just take your time. Partially set every 5 or 10th while checking the edge then go back making passes till all are partially set. Do it again till they are fully set. Keep watching the edge. It will be perfect.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 09-04-2015, 02:24 PM
great, thanks! ...if it starts to warp one way, how do you un-warp it?
Sammamish, WA
Old 09-04-2015, 02:44 PM
wjb's Avatar
wjb wjb is offline
I alternated my rivets, just to minimize any potential warpage. I went slowly; I did a partial set on all and then went back again to do a final set. I turned out very straight!
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Working the baffles
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2019 donation happily made
Old 11-13-2017, 03:19 PM
Mnemonics's Avatar
Mnemonics Mnemonics is offline
Default Alternate trailing edge rivets
Alternating the trailing edge rivets sounds like a nice symmetry to me.
With alternate you mean flush heads in the "even" holes on one side and in the "uneven" holes on the other side.
My question would be how to set those?
Since you have to set them partly in phases you could only rivet one side at a time, skipping ever other hole.
Is that going to be a problem?
Marcel Heijmans
RV-7 PH-MNX (reserved)
Blog ph-mnx.nl
Vlog YouTube: PH-MNX
Builder# 74668
Member NVAV
