Old 09-29-2015, 06:10 PM
Doug's Avatar
Doug Doug is offline
I have had some experience with polyurethanes - we learned a lot - plenty can go wrong. I do applaud your pragmatic approach and will watch for your progress.
The term 'polyurethane' is about as generic as 'fibreglass'. Rudimentary differences in the chemistry has significant impact on properties. Suppliers have a broad catalog of products and properties to choose from. Era http://www.erapol.com.au/products/cast-elastomers/ in my country is one such company, usually they will supply samples for serious potential customers.
The usual supply format is as a multipart (most commonly 2) resin. Mixing - simple pot mixing with stirrers will require de-gassing in a vacuum pot so requires a longer pot life, the next easiest is to use viscostatic (tubes with a series of mix blades inside) dispenser.
Pre-cast PU's such as sheet can be a mixed bag - pure PU will have a liquid clear appearance in an amber colour - be suspicious of a milky appearance or coloured stock.
Some boutique suppliers of PU formulations exist although I no longer have contact details for them. Tell them your requirements and application and they can provide formulations to suit. Tell them something can't be done in PU is like a red rag to a bull.
Doug Gray
RV-6 completed, flying since July 2010
Old 06-18-2017, 11:30 PM
madhun madhun is offline
Default PU Mounts
I happened across this post looking for an alternative use.
What was the verdict here Tool Builder; effective or otherwise?
My panel is lord mounted to reduce vibration to it, so not much of an issue with excessive vibration to the panel.
Quentin Carter
Bushby Mustang II - 170hrs and counting
$500, if Mrs. Hun ever asks aircraft parts are $500!
Old 06-19-2017, 06:38 AM
Toobuilder's Avatar
I tried running all 4, then just two, and eventually went back to the standard. Poly is effective at controling the spinner/cowl alignment and sag as expected but just a bit too harsh for a long cross country ship in my opinion. If it was a 30 minute per day acro ship, then I'd use them.
There are different formulations of poly that might work better, but its going to be a while before I have the time to machine up a mold and experiment.
Michael Robinson
______________
RV-8 - Flying
