This weekend I installed the flap gap fairings on my QB wings. After contacting the mothership for advice on a substitute for the inboard rivets, I started installing the MSP-42 cherry rivets suggested. During the pull on 2 of the rivets, the stem broke low enough that I can't get a grip to finish it out.
Afterwards, I thought I'd move to another job - correcting a goof on the battery box install in the tail cone. This is the intersection of F1029 and the F1007 frame. The suggestion from Vans in this case was a BSPQ-5-4. During the install the stem broke as well, but worse than that the bulb on the backside doesn't look even close to well formed.
Reason for my post is twofold:
First - I did enough of the blind fasteners on the horizontal to remember to keep the stem perpendicular to the piece. Is there anything else that could be causing the stems to break (tooling is my first thought)?
Second - Obviously these need to be replaced, but some technique suggestion would be appreciated. I had to drill out 1 previous blind with the stem still present and it turned into a disaster because the drill wandered and enlarged the hole. I don't want that in my spar. Any suggestions on an easy way to pop out the stem?
Sometimes even the easiest jobs are enough to drive you mad!
