David-aviator
That broken prop is a reminder that this business is risky. It has been around for 12 years, nearly disposed of a couple times with moves, but something always tells me to keep it. I almost ran it through a band saw recently for disposal but did not.
It happened with a Cozy pusher. An exhaust pipe broke and went through it. The break occurred under a heat muff and evidence of the break pending went undetected because I did not remove the muff for inspection in a timely manner. The muff attached to the pipe at welded flanges, that's where it broke. That system was changed to clamps as a result of the event.
I was never so scared in flight as that day - the vibration was terrific. The Holy Spirit moved my hand to shut down the engine in an instant and all was calm, the airplane did not come apart and was flying like a glider at over 10,000'. A military radar controller vectored me to Auburn. It was a bad day but a good day the way it ended. Took 2 weeks to get a new prop, dial check the engine prop flange, and fly home. A subsequent accessory case inspection by a mechanic revealed no damage to the engine. Lycomings are tough.
I wonder often where the missing blade is today? It happened about 15 miles northeast of Auburn, Alabama, so if anyone down there picked it up from a field, street or back yard and has it stashed away, now you know where it came from.
I lost confidence totally in pusher power that day and am in a RV because of it.
