Not surprising given the camber of the main gear wheels and that I mostly fly solo. After 115 hours and many landings the outboard threads are getting close to being wiped out on both tires while the inboard threads are like new. Which brings the question: could I turn over the tires bringing the inboard threads outboard? Inspecting the tires shows a symmetrical thread design and no indication of direction of rotation.
Have been doing this for several years now to get max use out of tires. Really need to align mine better as I believe most my wear is due to toe and it would help to be more vertical.....
It's more work than I like but also good time to look over the brakes and lines etc.
Always best to go to the manufacturers before the forums.....
Per Goodyear:
ASYMMETRICAL WEAR
Some aircraft tires exhibit faster shoulder wear on one shoulder versus the other
due to non-tire influences (camber-type wear, etc.). If this condition exists, the
tire’s life can be extended by demounting and reversing (“flipping”) the tire on the
wheel as long as tire wear limit and the physical condition criteria are satisfied.
NOTE: “FLIPPING” MUST NOT BE DONE ON SINGLE CHINE TIRES.
Just remember you won't get another 115 hours, maybe about half that. Keep an eye out for anything showing through. Per Michelin:
...be removed from service for wear
using the following criteria:
Based on the fastest wearing
location, remove tires:
When the wear level reaches the
bottom of any groove along more
than 1/8 of the circumference on
any part of the tread,
or
If either the protector ply (radial)
or the reinforcing ply (bias) is
exposed for more than 1/8 of the
circumference at a given location.
