Bryan Wood said:
Bob,
Sometime when your visiting your plane could you take a few shots of it and post the way that you sealed the side rails. This sounds good and I'd love more info.
[/URL][/IMG]
[/URL][/IMG]
Above is a photo of the rib clecoed to my canopy skirt and the final skirt.
I have a power point package I made up on the mod that I will try to send to you. The rib development process is fairly importabt to get the exact profile of the fuselage where the side skirts come down to it. Basically marked off the canopy sill every 1/2" as I recall, make up a table that has a cell (block) for every mark on the canopy sill, us a square to measured the distance from the maximum horizontal extension of the roller track to the edge of the fuselage at every mark, record every measurement, layout the points from a straight line on some pattern material (I use file folders), connect the dots with a gentle curving line, cut out the pattern, tape it to to a piece of 3/16" aluminum bar stock (I got mine from Aircraft Spruce), transfer the pattern to the aluminum with a Sharpie pen, saw out the anuminum rib, file the sawed edge smooth, trial fit it making sure to accommodate the structure and closure fiberglass band at the front and the narrowing space at the rear end of the roller track extrusion (the rib terminates in this area), drill evenly spaced mounting holes through the rib from the curved surface to the inboard edge, measure the distance above the canopy sill to the point where the canopy roller track curved surface outward extension is at its maximum, mark a line with a Sharpie pen on the inside of tha canopy skirt at this height above the bottom edge, clamp the rib inplace on the inside of the canopy skirt so the line is visible in the holes, back drill the canopy skirt through the holes in the rib clecoing every hole as you go, removed the rib, debur all the mounting holes (rib and skirt), countersing the rib holes on both the inside and outside surfaces, dimple the skirt holes, , clecoe the rib to the shirt, buy long rivets and cut to the required length for each hole as you go, squeeze the rivets in place with the manufactured head on the outside of the skirt and the shop flush head (double flush riveting) inside the straight inside edge of the rib, take the pattern used to make the rib and tape it to a sheet of rubber (I bought rubber sheet from Aircraft Spruce) set back from the straight edge the amount you want it to extend beyond the edge of the rib to effect the seal against the roller track extrusion, drwathe curved pattern on the rubber with a Sharpie pen, cut out the rubber and glue it to the bottom of the rib with 3M weather strip adhesive, repeat this whole process for the opposite side of the canopy. It not only seals the side skirts opposite the roller track but it forces the canopy skirt to conform exactly to the contour of the fuselage and it does not deform in flight, meaning it does not get sucked out into the airstream to form a minor cold air scoop.
This leaves four canopy seal ares to deal with, the interface between the side skirts aft of the roller track, the windshield interface, the rear skirt and the center track hole.
Van's says to have a skag formed by the rear skirt extend below the side skirt and overlap the fuselage to close off the opening aft of the roller track. I found that a 1/16" x 3/4" x 3/4" angle turned up and riveted back to back on the upper fuselage longeron from the aft canopy pin anchor block to the inside of the upper fuselage skin closes the opening just as well with several advantages (no air scoop effect, full contact with no potential fuselage paint scraping on closure).
I used the soft white "P" strip bought from Aircraft Spruce cemented to the aft and rear side skirts and the intersection between the roll bar and the fiberglass band to seal these ares upon closure.
Finally I used Tracy Saylor's idea of a sliding follower plug on the rear center canopy track and an aluminum hat on the rear canopy skirts to close this hole (which sucks air in surprisingly). Mine is made of balsa wood covered with fiberglass, stainless steel pull eyelets (made from safety heavy gauge safety wire that extend all the way thorugh the block on both sides and double back into the block), and waxed flat nylon wire bundle lacing tape (string) tied from the eylets to the bolt securing the slider block (four pieces all individually tied). I had to evolve this through several configurations before I came up with the one that works every time and lasts.
Bob Axsom
You have no e-mail listed so I will send the PPT File to Doug, perhaps he can forward it.
