colojo
Yesterday I flew my son and two of his college classmates from Denver Centennial to Greeley in my Mooney. On the return flight home I had quite a scare when an RV suddenly appeared in my windscreen, seemingly out of nowhere. We both had to take evasive action to avoid a collision; I'm guessing we were less than 500 feet apart, going opposite directions.
I was under VFR flight following with Denver Approach at the time, as is my custom. I notified the controller and he said he had no targets in my vicinity. My Mooney is equipped with Honeywell TCAS that paints bogeys on the G1000 moving map, and the RV didn't show up there, either. The way my TCAS works, if your transponder is on and you're close enough to me, it will see you.
The approach controller and I concluded that the RV's transponder was either not on or not working. This occurred well within the 30NM transponder veil for the Denver class B, so obviously a transponder was required.
Safety lessons from this event:
1. The area where this occurred is near the following airports: Longmont, Erie, Fort Collins and Greeley. All are uncontrolled fields. If you're departing an uncontrolled field, be sure to check your transponder during your preflight routine!
2. In 30 years of flying I've had two near misses, both while under radar surveillance (the first was when I was IFR in VMC; yesterday's was when I was VFR). Don't become complacent about other traffic, even if you're getting flight following. Fortunately I always keep my head on a swivel and was able to avoid disaster yesterday, but it never ceases to amaze me how difficult it is to see other aircraft and how rapidly we close on one another. This flight occurred midday, when it's especially difficult to see other aircraft.
Stay safe, my friends.
