As you know if you don't have brakes on an "A" model RV you can't steer it. I have now had both the static and dynamic failure experiences and they produced a couple of lessons learned. Earlier in the year I went out to the plane after visiting a friend in Panama City Beach, FL. I saw a wet area on the ground in the area of the right main gear. I didn't think much of it and I've had brake failures before and I have been able to touch the good brake for speed control and steer with the nose gear. I wanted to get home... I started the engine, applied a little power to overcome inertia and applied the left brake to come out of the tie down. The castering nosegear pivoted and the plane spun around the left main gear. The right brake was totally gone!There was no way to break the turn and all I could do was cut the power and hold it in its spinning location until the kinetic energy was overcome by rolling friction. My friend and I fixed the right brake problem with a lot of creative work but the line was disconnected several times in the process.
Fast forward several months until this past Sunday. I was flying out to Southern California and was making a fuel stop at Prescott. I landed on 21L and was well into the right turn off onto taxiway C-5 when the right brake went out instantaneously. When the aircraft is rolling it has some stability and the nosegear will not pivot over to the stop (limit). The remaining brake does work in a semi-normal fashion. I was headed for a colision with the first taxi light after the taxiway identifier sign and I was able to stear to the left of it by applying the left brake. When I released the brake, as you might expect, the the force of the moving airplane returned the nose gear to the center and I rolled out into the "grass" between the runway and the parallel taxiway (C). I had previously noticed the fitting on the right brake line was wet but it wasn't dripping so I did nothing about it. I now have a basic tool kit in the plane as a result of my Florida experience. After getting the plane towed to the ramp, I removed the fairing and found that the aluminum line was broken at the AN fitting. When I removed the AN fitting I found the flare still inside. I have a generous service loop so I was able to borrow a miniature tube cutter, a flare tool, a pump and hydraulic fluid from an aircraft service company on the field and fix it. The final lesson learned (there are several here) was, if the AN filling is wet, it is leaking and is not reliable.
Bob Axsom
Bob Axsom
