JanRV6UK
I did another quick check with my CAD model. If I move the F633 down just a little bit, it solves all my interference problems. So that is my plan. I'm going to double-check a few measurements first just to be sure. If that all checks out, I'll spend the $70 for new parts and be done with it.
Thanks everyone for your help. Having the pictures from other builders definitely helped clear things up. I'll report back once I get the new parts installed.
Hi Colin,
I have exact the same issue on my 6. Did you replace the two F633 in the end ? Moving them down a little bit ... Did you by any change measure the back and forth movement of the pushrod ? I do not have the space in my workshop to put the tail on - But as it is now I am able to get 2 1/4 total movement on the pushrod - I am wondering if that will give me enough elevator travel. I have the stick set up with 5deg forward tilt - and the rear belcrank dead vertical
