ACK ELT Turning on at startup
Wayne
I have my ACK ELT installed aft of the baggage compartment and the remote control on the panel.
Occasionally on starting the plane (master switch on, no avionics switch on) the ELT will activate. Must be picking up a electrical spike from starter or....? and causing it to turn on. There is no wires running from the ELT through the cabin that are live at start up.
Any suggestions?
Vibration, maybe?
Could it be reacting to the shake and shudder of the airframe as the engine cranks?
To isolate that, try removing it from its mount and resting it on some foam (or even a seat cushion), and trying it again a few times.
Diodes installed across coils?
I helped a guy with the exact same problem. He did not have diodes across the master and starter contactor coils. The transients generated tripped his ELT almost every time. Adding the diodes eliminated the problem.
John
Avionics
John
If that was the case... then fixing it probably prevented early failure of the expen$ive avionics in his panel..... :)
Gil in Tucson
John
Please tell me more on these diodes...
Diodes across coil
Relay and solenoid coils generate a negative spike across themselves when they are switched off. A diode across the coil with the band-end towards the (+) supply will become forward biased (turns ON) to 'short out' the spike generated as the magnetic field around the coil collapses.
Aero electric explains it pretty well here:
http://www.aeroelectric.com/articles/spikecatcher.pdf
Bob discusses several transient suppression ideas in this one and arrives at the diode across the coil. This may be a bit misleading as ALL coils should have a diode across them first. If you need to suppress arcs across contacts etc, that's a separate issue. His other schematics also show which terminals are which on the contactors and how the diodes hook up. The 'simple electrical schematic' in the RV7 preview plans also shows where to put them.
Note how with a 12V coil, he shows a -300 volt spike. That's about right and may actually be a bit low. I scoped one for grins at lunch and my battery contactor generated -500V across the coil when it let go (without a diode). It ALSO injected much of that into the BUS terminal. Even with internal protection, imagine how delighted your EFIS will be to have this presented on its power lines :D
Vans and lots of others sell ready made diode assys with install directions. Or you can roll your own. I used some 3Amp 1KV ones that I had around. Something like a 1N5408 will set you back a whoppin' 41 cents at Mouser and will handle about anything you throw at it. Put em right at the contactors keeping leads as short as possible.
1N5408 at Mouser
However you decide to do it, diodes across these (and any other DC coils) should always be included.
BTW: be careful when measuring voltage across large coils. A client of mine once called to say that every time he tried to measure the coil voltage on a (larger) 24V contactor, his DVM blew up, actually 3 of them did. Scoping it out revealed a 2500volt spike when the coil was shut off. Smoked the protection circuits on his el cheapo DVMs. He later added diodes across the coils and bought better meters.
And of course, I am sure that you NEVER would tell anyone to hold onto that no-diode 12V coil terminal while you cycled the master switch.. would you.. :eek:
Have fun,
John
How?
John
My ELT is not connected to the electrical system in any way - how would those transients cause the ELT to trip?
Rubber Ducky Antenna?
Dennis,
Did you use the antenna supplied by ACK? The owner/designer of the ELT that you are talking about is a family friend and he gave me a correction a couple of years ago for using a rubber ducky and mounting it in the baggage area. I did it because it is so common among builders to do this and have one less antenna outside the airplane creating drag. Here's a basic expanation as he gave it to me.
The provided antenna has a very narrow bandpass and drops off sharply for frequencies other than 121.5mhz. The reason that this is important is not for when it is being used as a transmitter in an emergency, but to protect the electronics from electric noise from tripping the thing on. He said that your own radios can trip the thing on, or others can when just rolling by and keying their mikes. This is not unique to this ELT either. There is a chance that noise from the alternator, starter, electronic ignition, etc. could be setting the thing off.
If this isn't your problem you should call Mike at ACK monday and give him a shot at your problem. I'll bet that he will know exactly what your problem is right off of the top of his head.
Let us know what you find if you could. This has me curious and I'd like to learn also.
Best,
update on ACK ELT
I talked to Mike at ACK and he gave a few test to do to help isolate the problem. It was also discussed how the Lightspeed electronic ignition that I have might be triggering it as well. The LSE II control box is only 1 ft away from the ACK remote head.
So off to the airport I went Saturday afternoon with tools in hand ready to tackle this problem only to find that I can get it to go off! Geez, I hate thinks that are temperamental and inconsistent!
Here is the plan if (when) the ACK ELT goes off again at engine start up. Shut down and:
1. retry starting again with the cable unplugged from the remote head. If this is the problem I will follow Johns advice with the diodes.
2. retry starting again with the fuse breaker pulled on the LSE. The LSE is identified as the problem I was told to purchase mu metal from Aircraft Spruce and wrap the LSE control box.
I will advise further when I become wiser.
Appreciate the input from all
diodes
regardless of the elt problem, i would think that you should check for the presence of the diodes on the contactors and install if not present. your avionics will thank you for it.
mho
Ahhh, thanks, johnp
I didn't want to harp excessively on the diodes but they are really NOT an option on the contactors. Why go to heroic measures to isolate each downstream system from bus nasties when you can clip em at the source? There will be plenty of other electrical issues to deal with.
To see for yourself, disconnect the master switch wire from the coil and touch it to the coil terminal (with the master switch on). Note the arc you get when removing the wire. That energy is going to go somewhere, onto the bus, across your switch contacts etc. Add a diode and repeat the test. No arc :)
Nuff said..
John
No problem - just curious
Bryan Wood said:
Dennis,
Best,
I have an AK-450 but I'm still building so I don't have a probem - yet anyway :rolleyes:
I was just curious how not having diodes on the starter contactor could trigger an ELT that is not connected to the elecrical system.
It's the switches...
Nuff said..
John
If you read the Bob Nuckolls' stuff, he explains that it is the switches that take the beating - that arc occurs inside the switch when it opens and eventually can (will) destroy the contacts.
Spark-gap transmitters..
..they worked for Marconi and they work for you too :D Tune a nearby AM radio off station, flip the switch and listen to the 'music'. Sparks radiate RF at lots of frequencies. This can get detected by a sensitive input circuit even if not directly connected. Good thing too, or we'd be flying with alligator clips on our antennas connected to the tower.. :p And as you wrote, those arcs are HOT, they can easily pit and erode switch contacts causing early failure or worse, weld them together. Not so good in a trim circuit, eh?
Another likely suspect is inductive (magnetic) coupling between the ACK remote wires and other wires in the harness that are carrying that transient coil energy and just like a transformer, couple it to adjacent wires. A recent consulting job had me looking at a customer's control design where he had (not too big) relay coil circuits sharing a 25' jacketed cable with a display module. Every time the relay clicked, the display went nuts. Adding diodes to the coils *sigh* suppressed the big transients so the display would survive but even then there was enough inductive coupling between the display and relay coil drives to cause it to 'receive' bogus characters whenever the coils were switched.
Figuring out what is going on in a 'noisy' environment can be challenging and require some high dollar equipment to track down problems. The best approach is to adhere to good design practices and address all of the things that you know will cause problems from the get go.
Then you can start on all of the stuff that you didn't anticipate :mad:
Ain't this fun?
