WhirlWind Propellers
I'm New Here
Hello to the members and readers of Vans Air Force forums.
WhirlWind Propellers is pleased to be a new advertiser with and in support of VansAirForce.net We will do our best to check in on the forum from time to time, but please also feel welcome to contact us directly with any questions or comments via email or telephone or our website.
To kick off this new advertising campaign we are offering following propeller package special to VAF members and readers good through December 15, 2014 only (see details below):
WhirlWind Propellers has a special offer for Van?s Air Force users on our complete RV propeller package for Lycoming 320 and 360 engines. This offer is good through 12-15-14 only. The RV propeller package includes the GA200L 72?/70" diameter ground adjustable propeller, 13? RV style spinner, 2.25? standard spacer for only $2,763 (Regular package price is $3453 - SAVE $690) *Must mention you saw this on Van?s Air Force site.
Propeller Description:
The GA200L-72 propeller system was designed for the RV type aircraft. Special attention was given to the RV airframe?s top-end speed and cruise performance. Design features include an optimized blade area, twist distribution and highly taped planform for minimum induced drag. Even the cowling and fuselage shape of the RV aircraft has been taken into account in the design of the GA200L-72?s blade shape, twist and airfoils.
Reasons to Choose the WhirlWind GA200L-72 Propeller:
- You only need to buy one propeller for multiple pitch setting options
- Performance flexibility: Pitch the propeller to your performance preference, such as top-end speed or super-efficient cruise
- Not all aircraft and engines are equal. Adjust the pitch to maximize your engine/airframe combination
With a conventional fixed-pitch propeller, you are stuck with what you have. Small airframe clean-up modifications and engine performance changes can necessitate a complete propeller change or re-pitch of your fixed-pitch propeller. With the GA200L-72 propeller you can immediately take advantage of airframe/engine performance improvements simply by making a small pitch adjustment without buying a new propeller or waiting to get re-pitched.
The GA200L-72 propeller is a well-tested and proven propeller system. The blades are designed using characteristics of our very successful constant speed propeller, the 200RV, but now in a lower cost ground adjustable option. The composite blades are extremely durable, and are equipped with an electro-formed Nickel leading edge for maximum protection from rain and other abrasion.
For more details check out our website:
http://whirlwindpropellers.com/aircraft/ga200l-two-blade-propeller/
Sincerely,
-Patti
Whirl Wind Propellers
"Leaders in Propeller Performance Technology"
[email protected]
619-562-3725
1800-C Joe Crosson Drive
El Cajon, CA 92020
Sincerely,
-Patti
[email protected]
619-562-3725
El Cajon, CA 92020
