Old 07-15-2014, 02:23 PM
DickF's Avatar
DickF DickF is offline
Default SL-30 Screen
The screen on my 14 yr old Apollo(Garmin) SL-30 has clouded up a bit. The clouding appears to be in a screen "cover". Might someone have a solution other than send it in to Garmin($$)??
Dick Flunker
RV-6A, 1900+ hours
North Texas
Old 07-15-2014, 02:29 PM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
I have only repaired an SL-40, which turns out to be the COM half of an SL-30. There was a fairly opaque piece of black plastic to optically isolate upper front panel from the lower. Perhaps it had drifted in placement and has become your 'cloud'.
New repair shop opening up: OTG
(Other Than Garmin)
GH
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 07-15-2014, 02:42 PM
Dean Pichon Dean Pichon is offline
I bought and installed a new screen on my SL-40. I bought the part from Garmin - not cheap, but much cheaper and faster than sending the radio to Garmin. I recommend you remove the radio to install the part as the are small lenses over each character that can fall out...
Goog luck
Old 07-15-2014, 05:33 PM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
actually comparing to the unit cost itself, the new face is relatively cheap. But new face will be Garmin and it will look like a brand new unit.
Amir
RV-7 QB - N174WM
Supporting VAF since the first visit
Old 07-16-2014, 07:47 PM
DickF's Avatar
Thanks for the info!
Dean, might you have ordering and/or contact info for ordering the SL-30 part?
Dick Flunker
RV-6A, 1900+ hours
North Texas
Old 07-17-2014, 10:44 AM
Steve Steve is offline
The clear window and the underlying dark lens came unglued from my SL40 last summer. I emailed Garmin about gluing them back onto the faceplate. They said no can do. Must purchase new items. Contact customer service. Cost will be $40.
This for 2 pieces of 6" x 5/8" plastic.
Five Sierra Fox
RV-9A
Utah
