glare shield edge cover
gerrydwhite
I'm New Here
I've been flying my RV9A for a year now but when I look at that knife edge glare shield it makes me uncomfortable with a sudden deceleration. I know that I've seen some padding for that edge but can't remember who sells it.
Not sure why this thread got close earlier, originally from gerrydwhite
Gerry, here is what I used and really like the look.
Goto McMaster-Carr and search for Plastic and Rubber edge trim with metal core, I think mine was the style #6
Covered mine with some split 3003 aluminum tubing, split vinyl tubing over that and glued the leather I used to cover the entire glare shield to overlap the edge
caution;
[/IMG]
Dash
Mine had a similar edge bead on it. Now imagine putting that nice little trim piece on a sword, and having someone hit you in the face with it!!!:eek:
If you look at typical crash victim reports, and photos if available, one thing repeats over and over. Facial lacerations, bruising, eye damage etc.
THere's a really significant likelihood that you or your passenger will NOT have their harness as tight as they should, and contact with something in the cabin is a certainty.
look at the dash of your car, and notice how most of the face killers have been minimized. Now look at the dash of our planes. Yech!:confused:
even with a 5-point, you can flail around like a rag doll. Race car design is another good example....all the sharp stuff is moved as far as possible, and well padded!
One of the first things I did was slit a chunk of fuel hose to go over the nice trim edge, and then a big fat roll of pipe insulation. Now we're getting close to something that will leave a nice big dent in your head, instead of a cut. The classic aero is a step in the right direction......
(bonus, you have a channel where you can run all those darn GPS wires etc. without drilling thru the glareshield!)
Yeah, I'm kind of a worst case scenario guy, but read about some crash survivors who said " it was difficult to egress the cabin due to all the blood running into my eyes...."
let's be careful out there! :)
Classic aero
My 9A has the classic Aero trim edge for the panel. It is an excellent product. I used the Welt edging at each end of the cushion.
Bill
McMasterCarr has lots of rubber edging you can use, for $10 you can likely do two glare shields. Not a great pic of the trim, but
