tomhanaway
My new Superior io-382 is scheduled for Sept. delivery for my rv-8a. The 190 hp version is warrantied for low lead. The 200hp uses 100LL only. Where I live, l premium gas without ethanol is available at regular gas stations.
I'll be running a constant speed Whirlwind 74rv prop. The prop calls for a minimum 200 hp but Whirlwind advises that it should be fine with 190.
I'm trying to decide between the two versions.
Shortish fun flights with the fun of takeoff is my primary use. Occasional long cruises. I'm skipping the 3 blade prop this time around although I loved the acceleration.
So, my question is, how much would I be giving up by going with an engine rated at 190 hp vs 200 hp for an rv-8a?
