I had previously posted about the problems I was having with a foil antenna mounted to the windshield of my -6. I added noise supression filters to the mags as the problem presented itself after having the mags overhauled. I finally decided that something had to be up with the foil antenna and indeed after close inspection I discovered that the foil had developed a crack which severed the antenna 1/3 of the way up. After searching the forums, I contacted Don Pansier by e-mail and asked him to call me. He called back within half an hour and we spent the next 30 min discussing my problem and I ended up ordering his bent whip antenna. He suggested mounting it ahead of the spar in the corner so that I get to it and could use the antenna with my handheld if needed. I had the antenna in two days and after installation I am thrilled with the results. I can highly recommend Delta Pop's antennas and they will be my first choice of antennas in the future.
