UnPossible
Hey- having fun figuring out how to get the cutout for rudder trim to work.
I am having a small issue with the geometry. I am using the RA servo with the shortest throw.
However, in order to get this to work, the control horn needs to be pretty tall. If I shorten it, the rod runs out of travel in slot in the skin.
I can't extend the slot any further, as it will hit the rib I made to stiffen the opening.
Am I missing anything obvious?
One more questions, I'd like to install a fairing over the slot and rod, but the Avery rudder fairings aren't tall enough... any ideas where I could find a taller version? Worse case, I'll fabricate one out of AL or fiberglass.
Below are a couple of pics.....
Jason
Jason
