Go Back   VAF Forums > Main > RV Ongoing Maintenance Issues
Old 02-03-2014, 07:00 PM
Lars Lars is offline
Default SB 14-02-03; RV-3, 4, 6/6A, 7/7A, 8/8A
http://www.vansaircraft.com/pdf/sb14-02-03.pdf
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
500 hours as of September 30, 2017
Old 02-03-2014, 07:22 PM
JonJay's Avatar
JonJay JonJay is offline
Lars - thanks for posting. This was a topic a few weeks ago as a few of these where being discovered. Lot's of theories as to why.
I inspected mine then and no issues.
However, now I have another note to make in my log book.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-03-2014, 07:31 PM
Arlen's Avatar
Arlen Arlen is offline
OK. This is 2 of these "check-for-cracks" Service Bulletins within a few days. For someone looking to buy a flying RV right now, this may be a bit disconcerting...
Arlen
RV-6, February '14, SOLD December '15
Old 02-03-2014, 07:34 PM
Snowflake's Avatar
Never mind someone looking at buying an RV... How about those who own them?
Maybe we should all just buy new tail kits and be done with it...
Rob Prior
Old 02-03-2014, 07:44 PM
Walt's Avatar
Walt Walt is offline
I've been looking for this problem since this came up a quite a few months back, have not found any cracked.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 02-03-2014, 08:17 PM
Captain_John's Avatar
Wait till ALL the SB's are out first!
. CJ
RV-7 Flying - 750 Hours in 3 Years!
Old 02-03-2014, 08:18 PM
scsmith scsmith is offline
Default Rod bearing jam nuts
I'm disappointed that there is not a special admonition in the bulletin to be sure the jam nuts are tight. If the jam nut is not tight, all the hinge load goes into the little ears on the plate nut, and into the two little rivets that hold the plate nut to the elevator.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 470 in 8 years
also LS-6-15/18 sailplane
VAF donation Dec 2017
Old 02-03-2014, 08:31 PM
rhill rhill is offline
Default Vertical SB??????
By the end of the week ???? Prop wash has always been an issue, with the steps,the old folded rudder,the tail in general takes a heck of a beating,moving the plane around the hanger,where does everybody want to push? I feel bad for the guys with expensive paint.and what paint isn't expensive.The old joke was,you might as well order two tail kits to cover spare parts you'll mess up. Well its time to dust off the spare parts.
RHill
Dues paid in 2016
Old 02-03-2014, 09:01 PM
wjb's Avatar
wjb wjb is offline
Default Proactive doubling?
OK guys ... what about us whose HS is in the rafters waiting for the rest of the airplane to catch up? I read with great interest the earlier set of posts about properly torquing the jam nut. Clearly, this is a weak point if not assembled correctly. Any benefit to do the doubling proactively? Easy to do now, given that the Hobbs is at about -2 to -3 years till first flight.
Bill Bencze
N430WB (reserved) RV-7 #74152, tip-up. Avionics and FF underway!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2018 donation happily made
Old 02-03-2014, 09:02 PM
I followed the cracking elevator spar thread Jon, so I wasn't entirely surprised to see this. As Walt mentioned in the other thread, my eyes aren't exactly young anymore, so I went over my elevators with a 10X eye loupe, looking for said cracks. Lucky me, found none. Also the jam nuts were, well... jammed. Tight. I give them a cursory look every preflight. Will look again and make the requisite logbook entry. Not that it matters, bum shoulders are going to keep me on the ground for awhile
Lars Pedersen
Davis, CA
