Hey yall,
I'm hoping some of you smart folks will chime in here and help push me in the right direction with my electrical distribution system. First off, thanks to all the folks who have already been there done that and posted their results. It was really helpful for me starting from scratch with electrical design. If my design looks familiar, it's because I blatantly stole elements from posts on this site.
Let's just say the electrical portion was a lot harder for me than I thought it would be.
Design Overview:
Like many others on this site, I did not see a need to re-invent the wheel here. I pretty much followed Bob Nuckoll's architecture and what others had done. KISS, right? Well, maybe I went overboard but my goal is a simple to operate (and maintain) electrical system.
Paul Dye said something that stuck in my head : re-defining avionics to only the radios....not the PFD/MFD. I knew I wanted the G3x screen(s) to be on prior to and during engine start to monitor the engine. The thought of 2 alternators was a bit much (weight, complexity, and cost) for me, so I opted for 2 batteries instead. This "backup or brownout battery" would allow me to dual - feed an endurance buss and also power up and keep alive the G3x during cracking. Kudos to Garmin for integrating dual power inputs.
Design Goals:
Simple to use, reliable. Few parts as possible. Affordable.
Eventually, I would like to use the plane IFR, so reliability is important.
If I wasn't on a budget I would have gone with a VP-X, but frankly it's too expensive for me to consider replacing the fuse blocks and the cost-benefit analysis did not come out favorable for my conditions. Looks like a nice product, but too rich for my blood.
Equipment:
Right off the bat, you can see I've got some single failure points.
The avionics are dependent on the relay/switch. I've heard the arguments for removing them, but I could not figure out a way to keep them off during engine start but make sure they are running at all other times. Garmin tech support agrees, and while the components are capable of withstanding voltage spikes and all that, it is preferable to have them off during engine start. Plus, the ADS-B, ARINC, Audio panel, and Transponder do not have an "off switch" of their own. I see the risk as acceptable, because I don't think the relay would dropout/chatter/fail in-flight, but rather show symptoms on the ground. Losing the radios is not ideal, but I would still have the endurance and main buss. Of course, if someone has an idea how to isolate the avionics bus during startup but have it on all the rest of the time please show me (maybe a fancy 3 way switch?)
The aux charger was a cool find from Jack Maljaars. It liminates diodes, resistors, fuses that are needed to link the primary battery to backup for charging. Limited to 3A and only comes alive when primary voltage is above 13.3V. Plus it as UV/OV protection. Pretty cool and I think a nice alternative to an alternator, though not as powerful.
The ztron labs solid state relay was found in a box that I got when I purchased the project. Figured, why not?
I'll have 2 circuit breakers (pullable) - 1 for the Alternator Field and 1 for the servos.
Seat heaters will be re-wired for tefzel, and the relays replaced the same type as the avionics for spares.
Design Overview:
Design Goals:
Equipment:
- Main Batt: PC680 (possibly antigravity LiFe0 in the future if compatible with alternator)
- Alternator: Plane Power 60A internally regulated
- Backup Batt: SLA-12V7-F2 7.6Ah
- Ebus solid state relay: Ztron Labs ZL-MB50
- Avionics relay: B&C 40A
- Backup Batt charger: Sterling Products Battery maintainer
- Boost pump: Airflow Performance 3090050
- Switches: B&C 1-3 and 2-10
- E-bus diodes: B&C D-25
- Wire: Tefzel 20 AWG to most, 14 AWG to pump, 16 AWG to lights/flaps, and copper bus bars from battery contactor to start contactor/anl fuse.
