gerrychuck
Posted on the "How cold is too cold" thread, but thought I'd post it separately to solicit advice:
I think I jinxed myself; after bragging about my New Years Day cold weather flight, I went back to the airport yesterday to fly (in much milder temps) and discovered a 2" crack in the windscreen, probably from the cold temps last time out. Bummer. The crack is at the bottom of the screen on the passenger side at the "corner" where the screen curves from the frontal plane to longitudinal. It can't be seen from inside the cockpit at all, and there is zero separation; can barely feel it with a fingernail.
I know I should stop drill it; but would appreciate advice re: techniques, bit sizes, etc for doing so. With no separation, I don't know if it needs to be glued as well or if this isn't needed. Again, any advice appreciated.
I apologize for the lack of pictures; for some reason I left my phone behind at the house when I left for the airport yesterday.
From what I have been able to learn from searching this forum and a more general google search, it appears that stop drilling is a given, but the questions I have are mainly related to drill bit type and size: Some people are adamant that you need to use a plastic bit, which I don't have, and others say that for stop drilling it isn't important since the plastic is already cracked. Also, many suggest a very small bit size, such as 1/16, and the plastic bit sets I've looked at online seem to start at 1/8.
After drilling, it appears that gluing/sealing with Weld-On #3 is in order, according to what I've read. Any hints on how best to do that would be appreciated.
Fortunately, the repair does not have to be perfectly transparent or even look particularly good cosmetically; as noted above it is not visible from the cockpit at all, so my concerns are purely to prevent further propagation of the crack.
Thanks in advance!
Thanks in advance!
