Old 12-30-2013, 03:58 PM
johnfurey johnfurey is offline
Default I Took Up Smoking
I have finished installing the Smoke-System Helper. First off thanks to Craig Taylor and Marvin Holmsley for their help. The install was straight forward, not difficult, and no surprises but it does take a little time. Actually just the kind of project I enjoy at this time of year.
I have often wanted a smoke system but several things always kept me from installing one.
1) I didnít want to give up baggage space.
2) My CG is already aft due to the WW prop.
3) I wanted to be able to remove the system quickly and easily.
4) I didnít want to pay big bucks for the oil.
5) I didnít want lots of oil on the belly.
6) If I wanted to get rid of the system I didnít want to permanently scar the plane.
Marvin and his Smoke-System Helper provided everything I needed to eliminate or reduce my objections to an acceptable level. Here is how I did it.
1)Marvinís tank takes up very little space in baggage area.
2)The CG moves aft only a little (see details below)
3)The tank takes 2 minutes to remove and the pump another 30 seconds. With quick disconnect fittings on the tank and pump along with 1 spacer instead of 4 washers on each side and latch pins instead of nuts on the mounting bolts.
4)Marvin recommends used ATF which I have available to me.
5)With 2 nozzles mounted forward on cyl # 1 & 3 I am hopeful that the mess should be reduced.
6)Installation was done so that the entire system can be removed with no unsightly blemishes.
W&B:
With the system installed but no oil my empty CG went from 80.94 to 81.25 and 82.19 with full oil.
My normal flight condition with Pilot, Passenger and Full Fuel went from 84.80 to 85.45.
Obviously adding baggage and burning off fuel moves CG aft but it is all manageable within my comfort range.
I made a simple sight gauge for the side of the tank which I am very happy with. The only thing I have left to do is paint the tank and the project will be complete.
[IMG][IMG][/IMG][/IMG][IMG][IMG][/IMG][/IMG]
John Furey, RV7. Ohio
Life's Short...Fly Often!
Old 01-01-2014, 11:57 AM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Default Nice Smoke System
I had a chance to look at John's install last Saturday. If I were to put a smoke system in a side by side RV this would be my choice. Nice and simple and VERY easy to remove with almost no obstruction in any part of the airplane.
One very nice feature John added was the sight tube as seen in his pics. Makes it super easy when filling or just verifying oil level prior to departure.
No affiliation with the maker of the kit other than he seems like a super guy and John had nothing but pleasant comments about the experience, which is good enough for me. Maybe I need one of these after all
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
Whirlwind Prop Dealer
EAA Oshkosh Homebuilt Judge / EAA Tech Counselor / EAA Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox, RV4, 6, 7, 8, 9, 10, 12, & 14ís
6 RV10's Finished
F1 Rocket #1 Oshkosh Grand Champion :-)
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
51 RV's & Rockets & counting
http://www.rvrick.com
Love my Pitts S-1S
Old 01-01-2014, 12:18 PM
Brantel's Avatar
Brantel Brantel is online now
John,
Any pics on how you got the oil line fed thru the spar?
All my holes are full of wires!
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-01-2014, 06:19 PM
Sorry Brian. I just deleted all of those today since they didn't turn out all that good. Marvin supplies a high quality hose with the kit but I used a thinner wall, more flexible urethane hose compatible with fuel and oil. It was inexpensive and purchased from US Plastics where the quick connect-no drip fittings came from. The fittings are only don't drip after they fluid between the connections leaks out so you do need to catch a very small amount but they are cheap and handy if you plan to remove the tank from time to time. I ran the hose thru the floor board then forward where it makes a 90 and goes thru 2 ribs then forward under the aileron controls(because I already had wires going thru the spar on the outboard bay I used the bay next to the outboard bay) and thru the spar then makes another 90 and goes over to the floorboard and tucked under the lower longeron where it is totally hidden and runs forward to the fuel tank vent and follows it up where it makes a 90 over to the firewall bulkhead fitting. I used 3/4" snap bushings 5 places the hose went thru metal(2 on the spar, 2 on floor ribs, 1 on floor) It was very easy to get the hose from the pump to the firewall and I will try to get a few pictures for you.
Old 01-02-2014, 06:35 AM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Nice work John, that pump install is slick...I didn't even consider that location when I did mine but I sure do like it.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 01-02-2014, 08:47 AM
Thanks Ron. I'm very happy with the set up. Brian, here are a couple of pictures showing the line going forward of the spar. Like you my holes were already filled so I drilled another 3/4" hole for the hose.
Old 01-05-2014, 04:28 PM
I had a request to see how the top of the tank mounted with a tip up canopy
Old 01-05-2014, 05:13 PM
Snowflake's Avatar
In the spar? Where?
Rob Prior
Old 01-06-2014, 09:10 AM
Well, not in the spar actually. In the spar web where Van has them for wires and such.
Old 03-10-2014, 12:03 PM
BillC BillC is offline
More of a question than a reply.
Other than drilling another hole in the spar (I'd rather not) how have those with tanks behind the passenger seat routed their oil line to the firewall? I'm installing the same system as John and don't like the look of the black hose going over the spar section before it goes down thru the gear leg support.
Bill
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
