Can someone tell me if there is any leftover 125 x 3/4 x 3/4 angle when you finish the rv10 fuse? And if so, how much? I'm thinking of redoing one of the longerons because I messed up a hole real bad while drilling.
While I'm here, I might as well ask for some advice. How did you drill this longeron to the gussett (page 29-9 step 3)? Basically, you have to drill 5 holes up from the bottom of the gussett into 1/8" angle and you can't see what you're doing - not to mention clamps interfering with your every move. I set up a mirror and used a 90 degree drill. ..... 4 of the holes went fine, but on one the drill wandered A LOT before I realized it, and the bit popped out of the longeron on the inboard edge. It's not easy at all drilling while looking through a mirror. .... Anyway, maybe I can deal with the issue by cleaning up the bad holes and using a doubler on the bottom of the gussett and on top of the angle. I'm sure this would be strong enough, but I'm not sure if nesting a section of angle into the damaged angle as a doubler will interfere with something later. Anyone remember?
