Old 11-10-2013, 12:35 PM
Default Fuel Quick drain leak
My Quick drain fuel drain is leaking. I think I've read that there's an O ring in there that usually is the culprit. Anyone know offhand what size that is? Maybe I can find one over at Ace.
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 11-10-2013, 12:53 PM
Walt's Avatar
Walt Walt is offline
You can usually just pull them out and clean the debris from around the O ring.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 11-10-2013, 01:09 PM
terrykohler terrykohler is offline
Default More Often, It's Debris In The Tank
Bob:
Before you pull the drain, try "working" it up and down. If that doesn't work, you can pull the fitting, but as already mentioned, you can more likely just clean it. I carry a spare valve assembly, so I can easily swap it out. Both times I've done so, it only required cleaning.
Terry, CFI
RV9A N323TP
Old 11-10-2013, 02:01 PM
bhester's Avatar
bhester bhester is offline
http://www.aircraftspruce.com/catalo...clickkey=98505
http://www.aircraftspruce.com/catalo...fuelorings.php
MS29513-006 1/8 1/4 1/16 $0.24
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2018 VAF donator - alot better than any magazine subscription
Old 11-10-2013, 03:57 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Always have a spare
I keep a spare with a fresh O ring ---- easy to change them out (not more than 10 gallons of fuel down the arm) (just kidding, only a little spillage) -- I have spare O rings and just "rebuild" the leaker and have it ready to go back the next time.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 11-10-2013, 04:07 PM
Very handy info to have, so I moved this thread to "Ongoing Maintenance" and made it a sticky.
Old 11-10-2013, 04:34 PM
Scott Hersha Scott Hersha is offline
If you plug the tank vent with a golf tee or piece of tape, it won't leak much while you make the change.
SH
RV-8
Cincinnati, OH/KHAO
Old 11-10-2013, 05:21 PM
agough277 agough277 is offline
MS29513-006
RV6A, RV7, RV6 Wing
Living with my 6A at 3L2 near Las Vegas
Old 11-13-2013, 09:37 AM
krw5927 krw5927 is offline
Post
McMaster carries Viton o-rings which work perfectly and are ethanol resistant, for those of you who may use the forbidden fuel. Part number 9464K11 will get you 100 of the little buggers.
Bob, if you need a few send me a quick PM with your address and I'll throw some in the mail.
Kurt W.
RV9A
FLYING!!!
Old 11-13-2013, 10:02 AM
bkilby's Avatar
bkilby bkilby is offline
Anyone have a part number for a plug to screw in the sump drain? Might be handy to have on a trip if you find a drain leaking and don't have another drain/o-ring to replace it
Brian Kilby
flying RV-6A, previously flying RV-9A
based at KCTJ, Carrollton, GA
