Old 08-18-2013, 11:06 PM
hydroguy2's Avatar
hydroguy2 hydroguy2 is offline
I didn't take many pictures during that phase of the build. too busy trying to get it ready for paint.
It's just one Dam job after another
Brian, N155BKsold
Old 08-19-2013, 01:05 AM
gblanck gblanck is offline
Default illustrated guide
Originally Posted by Ironflight View Post
OK, so who is going to be the first to write me an illustrated guide to the hinge method for Kitplanes?
You can PM me if interested....
I followed the excellent description here: http://websites.expercraft.com/n51pw...y&log_id=23961 and am really happy with the results.
-Greg
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
Old 08-19-2013, 05:03 AM
GLPalinkas's Avatar
GLPalinkas GLPalinkas is offline
I would love to see just that. I used the #4 screw kit from Cleaveland but would have gone the hinge route if I had known/thought about it. I might even consider a re-do because the 4's are a pain.
Gary Palinkas - Gman.... VAF #161
Venice, Fl
RV-6 "Sassy" Flying 400 hrs since Oct 2011
Lycoming 0-360 A1A, FP Sensenich Prop
SARL #19 .... Van's Calendar March 2015
Although exempt several ways, =VAF= Dues paid to support this awesome site/family
Old 08-19-2013, 08:00 AM
flion's Avatar
flion flion is offline
I plan to mount my tips within the next year (probably Spring) using the hinge method. If you can't get permission to use material from the expercraft site or anyone else, then we could probably coordinate what pictures you wanted (or even get a real photographer) as well as a write-up.
Patrick Kelley - Flagstaff, AZ
RV-6A N156PK - Flying too much to paint
RV-10 14MX(reserved) - Fuselage on gear
http://www.mykitlog.com/flion/
EAA Technical Counselor #5357
Old 08-19-2013, 08:11 AM
bullojm1's Avatar
bullojm1 bullojm1 is offline
I thoroughly documented my hinged wingtip install. Here are the links:
http://www.rvplane.com/?categoryid=3&dayid=567
http://www.rvplane.com/?categoryid=3&dayid=568
http://www.rvplane.com/?categoryid=3&dayid=569
Top of this page: http://www.rvplane.com/?categoryid=7&dayid=946
Bottom of this page: http://www.rvplane.com/?categoryid=7&dayid=959
Top of this page: http://www.rvplane.com/?categoryid=7&dayid=960
Mike Bullock
RV-7, Flying!
Old 08-19-2013, 11:47 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
When I first mentioned this method above, in the back of my mind was an old RVator with the method described and as far as I know the best documentation of how it is done was on Chad Jensen's website. I would recommend him. However, Chad's employer may not like him writing for the opposition.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 08-19-2013, 01:24 PM
MarkW's Avatar
MarkW MarkW is offline
I used hinges and looked at Chad's site and Mike Bullock's site. Mike used a much better method for locating holes. Chad's method although I am sure it works, involved more time and work.
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 08-19-2013, 01:40 PM
Bob Axsom Bob Axsom is offline
Default I guess if you are not concerned about changes...
I guess if you are not concerned about changes then whatever hangs them on is fine. Mine come off and are changed to alternate configurations for travel, racing and development. I use #8 screws and the heads are painted to match the airplane (not stainless steel). In other areas where I want it obvious that the screws are to be removed in normal service I sometimes use stainless steel screws. It simplifies maintenance if all your screws are the same size - for me I use #8s everywhere. I think I bought 100 #8 screws one time pressed them into cardboard and painted the heads blue with Imron but I also have a lot of unpainted #8 screws and the most common length is 1/2".
Other #8 screw locations. fairings (many), removable steps, cowling split lead cover plate. A burred head is a quickly solved problem.
Bob Axsom
Old 08-20-2013, 06:59 PM
GAHco's Avatar
GAHco GAHco is offline
Default Better 4-40's
NAS514's hold up as they are made of higher tensile steel.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 08-21-2013, 12:59 AM
gasman gasman is offline
Paul, you might want to contact Mark Phillips (Possum works). He was the one that developed this process back in 2003.
http://websites.expercraft.com/n51pw...y&log_id=23961 There are now better ways to do the installation, but Mark was the first.
The process here...... http://websites.expercraft.com/n51pw...ry&log_id=5181
Warren
VAF #897
2017 =VAF= Dues PAID
