krazydoc33
Member
Hi, I am one of those that did the wiring form the D180 Flight Deck and then waited for the Skyview conversion. This is based on the early 08-25-11 wiring kit that came without the harness for the pilot and co/pilot to connect to the AV5000. I made my own and have been trouble shooting it on and off for about 5 months. The major problem was that in the isolate position on the 403 intercom the radio reception was not usable, in the intercom position the radio transmissions were too weak to be useable. I also had a bad co/pilot head phone jack, some times intermittent some times open, I gave it the foot treatment and replaced it. The main problem remained, why the difference in radio reception between intercom and isolate?
Everything with the wiring and the schematics checks out OK.
The problem that I finally found yesterday was the there is a discrepancy between the wiring in the WH 00036 conversion harness. The wire on pin # 3 that goes in the conversion harness as pilot PTT comes out on pin #3 at the AV5000 labeled as co/pilot PTT. The co/pilot PTT wire on pin# 2 also changes it's name at the AV5000 to pilot on pin #1. I swapped pins #1 & 3 at the AV5000 d-sub and all problems are now gone! Van's was not aware of this wire switch and they will correct the wiring diagram. An easy check to see if you have this problem switch the intercom to isolate and try transmitting from the co/pilot side and/or see if your radio signal gets very weak on the pilot side when switching between intercom and isolate.
I still have some hair left, but not much!
HTH, Henry
HTH, Henry
