I back riveted the top skin on my left wing, and quite frankly am not thrilled with the results. I had to use a double offset back rivet set, and far too many of the shop heads are not straight. They're not bent over enough to justify drilling them out, but I'm just not too happy with them.
On the right wing we've been using a large mushroom set with a rubber ring, and a tungsten bar on the inside. The results on the shop heads have been far better, and the flush heads are just as good as the other wing. Maybe someone else has had better luck back riveting skins on, but I won't do it again.
